broken piston
Old May 23, 2005 | 11:50 PM
  #16
EviLZ28's Avatar
Re: broken piston
I would check the fuel pump to make sure it is up to spec. If the motor did lean out when the nitrous was applied, Then that would be a severe case of detonation happening.
Old May 24, 2005 | 06:37 AM
  #17
LameRandomName's Avatar
Re: broken piston
Forgetting all the safety stuff that is so popular today, even with a full manual control system you should be fine as long as:
1) Your N/A + Nitrous levels don't add up to more than your engine is designed to handle,
2) Your fuel system is such that you have sufficient volume AND pressure, plus of course enough octane, and;
3) You don't get into detonation.
Old May 24, 2005 | 03:53 PM
  #18
526 SS 96's Avatar
Re: broken piston
I would check the fuel solonoid. It's possible that it may have closed (lost connection, or bad noid, or cloged, or stuck closed) Yor FPSS would not have any way of knowing something like that was wrong. It is very strange, like the other guys said it's not really alot of nitrous and it should not have killed the motor. I ran a 200 shot on a 85K bottom end and nothing went wrong with it (it was only 4 passes but I still did it).
Old May 24, 2005 | 05:10 PM
  #19
12Second3rdgen's Avatar
Re: broken piston
I agree. How long have you had these solenoids and have you ever had them rebuilt?
Old May 25, 2005 | 09:44 AM
  #20
silverz28's Avatar
Re: broken piston
It was a brand new kit when I bought it last summer. Why wouldn't the FPSS shut everything down if the fuel noid was not working? I thought that is part of what it's purpose was.
Old May 25, 2005 | 10:56 AM
  #21
Re: broken piston
All the FPSS does is monitor fuel pressure before the solenoid. It has no way of knowing if the solenoid actually opened.
Old May 25, 2005 | 11:02 AM
  #22
Re: broken piston
The FPSS generally sees the pressure before the fuel solenoid. It has no way of knowing if the solenoid is stuck closed.
Old May 25, 2005 | 11:57 AM
  #23
rskrause's Avatar
Moderator
Re: broken piston
Originally Posted by slomarao
If you are building a forged bottom end 383 than it should with stand a lot. A lot like a 250-300 shot, I understand your fear of deastroying another motor but in your case something wasn't right with your stock shortblock, that is why it gave way to the 75,100 shots. Pull some timing and add higher octance gas when spraying in the future. I am not the best on diagnosing what happened to you previous motor. good luck
A 250-300hp nitrous shot on a small block is a lot no matter what kind of rotating assembly you are running. It really pounds the hell out of the bearings. If you plan to run that much nitrous very often, I'd be tearing the thing down at least once a year.
But that's just me, others don't feel it's necessary.
Rich
Old May 25, 2005 | 12:15 PM
  #24
Re: broken piston
Rich -
Would you have the same concern about a 300hp nitrous system that begins at say, 50hp and comes on progressively over several seconds?
Old May 26, 2005 | 07:04 AM
  #25
rskrause's Avatar
Moderator
Re: broken piston
Originally Posted by LameRandomName
Rich -
No, that wouldn't be as much of an issue. Especially if you don't try to bring it in at low rpm.
Rich
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
mmf_1013
Sep 12, 2015 08:56 PM
Toxintwins
Sep 11, 2015 11:13 AM
maverickmk
Sep 1, 2015 09:17 PM
