best place for WOT sw for compucar kit?
Old Jul 29, 2002 | 08:51 PM
kev93z28's Avatar
Question best place for WOT sw for compucar kit?
i just bought a compucar kit online , dont have it yet but discovered it doesnt have a WOT switch.whats the best place to get one that will bolt right up fairly easy without having to modify it.ive considered the TPS ones but looking to spend less if possible. thanks kev
355,ported heads,forged pistons&rods,cc 220 224 cam,triflo,ed wright,moser 12 bolt 3.73,spohn ta,old tune->345rwhp @ 5200 rpm 453ftlbs flywh torque @ 4500 rpm(should have tested to higher rpm on hp)
Old Jul 29, 2002 | 09:51 PM
gb95zconv's Avatar
Post
Mine is under the gas petal....floor it and its on.
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
Old Jul 30, 2002 | 07:20 PM
1FastRedZ's Avatar
Post
I wouldn't put it under the gas pedal. My throttle cable has broke a couple of times and the pedal sticks to the floor. I was glad it wasn't there. I have the Compucar plate kit and bought a NOS switch. The braket for the switch has three big oval holes I had to grind on the middle on to get it to fit. If you want some detailed info e-mail me. I'll be glad to help you out. I had it rigged up on the button they give you and about blew the thing up.
95 Z28 6 speed
Sprayed with other go-fast parts.
Old Jul 30, 2002 | 07:57 PM
kev93z28's Avatar
Post
thnaks for the reply guys. i looked up the nos one at summit and its only 11$. so i am going to pick one up. i might drop you a email fastred if i run into any probs. thanks kev
Old Jul 31, 2002 | 07:45 AM
Redbird's Avatar
Cool
I put mine on top of the throttle body right above the nameplate.
HInk
Victor Lamb
Aug 26, 2017 02:52 PM
R@mpage
Apr 20, 2015 10:02 AM
captcorvette
Mar 7, 2015 12:37 PM
dbrockma
Feb 16, 2015 02:56 PM
