best place for WOT sw for compucar kit?
i just bought a compucar kit online , dont have it yet but discovered it doesnt have a WOT switch.whats the best place to get one that will bolt right up fairly easy without having to modify it.ive considered the TPS ones but looking to spend less if possible. thanks kev
355,ported heads,forged pistons&rods,cc 220 224 cam,triflo,ed wright,moser 12 bolt 3.73,spohn ta,old tune->345rwhp @ 5200 rpm 453ftlbs flywh torque @ 4500 rpm(should have tested to higher rpm on hp)
Mine is under the gas petal....floor it and its on.
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
Greg
95 Z28 conv M6
NX 150 progressive,
I wouldn't put it under the gas pedal. My throttle cable has broke a couple of times and the pedal sticks to the floor. I was glad it wasn't there. I have the Compucar plate kit and bought a NOS switch. The braket for the switch has three big oval holes I had to grind on the middle on to get it to fit. If you want some detailed info e-mail me. I'll be glad to help you out. I had it rigged up on the button they give you and about blew the thing up.
95 Z28 6 speed
Sprayed with other go-fast parts.
95 Z28 6 speed
Victor Lamb
Aug 26, 2017 02:52 PM
