Is anybody running a 255 Intank Pump and a 255 Inline Pump?
Is anybody using a 255 intank pump with a 255 inline pump? I think that will support everything I need right now. If I were to run a smaller inline pump, would it restrict the intank pump?
Would a Vortech T Rex restrict the 255 intank pump?
Somebody has ran a a big inline pump with a big intank pump. :)
I can't tell - is that a wet kit or a dry kit?
Dave |
Yes but why would that matter? I have a Granatelli 255 Intank Pump but I want more fuel.
It would matter because if you have a wet kit, it needs *more* fuel, but at the same pressure. If you have a dry kit, it needs *more* fuel, and *higher pressure*. I'd think your single in-tank pump wouldn't have an issue at all, if you have a wet kit. But if you have a dry kit, an in-line booster pump to raise the pressure is usually the solution.
Dave |
Thats what I thought. The volume is still going to be a problem spraying a 200 shot or more I think. I want stock pressure with more volume. I dont think the 255 intank pump is going to be enough. It's a different setup than the setup in my signature.
Ah. If it were me, I'd be looking for one larger pump, then... Probably what you're hoping not to have to do.
Dave |
I dont think they make any bigger and it's a brand new pump that just got put in so I dont want to have to get another one anyway.
