150 Shot
Old Feb 11, 2005 | 05:49 PM
94NDTA's Avatar
150 Shot
I plan on running a stock bolt on LT1 for a year, maybe 2 before upgradding.
I have a 100 NX shot on a stock fuel pump, stock injectors, and a Mallory 685. If I wanted to go to a 150 shot I know I would need a new fuel pump (any suggest one that will get the job done for a couple years) but do I need to upgrade my injectors? Thank you.
Old Feb 11, 2005 | 06:13 PM
25THRSS's Avatar
Re: 150 Shot
You wouldn't need to upgrade the injectors unless it's a dry kit.
Old Feb 12, 2005 | 12:32 PM
94NDTA's Avatar
Re: 150 Shot
Allright, then what would I need to up to a 150 shot? I should have plenty of traction (spohn suspension + ET streets), I have an aftermarket ignition, colder plugs, all the safety options. I only have 92 octane in my town, so I would plan on pulling 6* timming. Would I need my computer tuned? I also know I run the risk of blowing my tranny or rear. Where can I get an intank walbro?
Old Feb 12, 2005 | 03:53 PM
Sparkz28ss's Avatar
Re: 150 Shot
Racetronix has a nice intank setup...I would go with that and stall so you can leave on the dope....should make for a quick Lt1
Old Feb 12, 2005 | 04:09 PM
Kryckter's Avatar
Re: 150 Shot
Rear end is prob. going to go...if it is a 10bolt that is.
Other than that, Sounds like you got everything in line to make it safe and very fast.
Good Luck
Joseph
Old Feb 12, 2005 | 06:59 PM
Derrick Redd's Avatar
Re: 150 Shot
I got my 255 lph Walbro from Jegs. I looked at your webpage and see you have an auto. You should be fine on the dope, I'm running times in sig with a 10-bolt. Best 60ft of 1.55.
Old Feb 13, 2005 | 06:20 AM
brubble's Avatar
Re: 150 Shot
More Performance has the cheapest Racetronix plug and play walbro pump.
thats where i got mine and i love it.
Old Feb 13, 2005 | 11:17 AM
LT1Squirrel's Avatar
Re: 150 Shot
your 10 bolt will be fine behind the auto for a while
Old Feb 13, 2005 | 01:18 PM
94NDTA's Avatar
Re: 150 Shot
I have a fund for a TH400 or a 12 bolt/9 inch if either go out. Lets just hope that they don't go out at the same time. How hard would it be to hook up an intank fuel pump? Anyone have a link to an install?
Old Feb 13, 2005 | 03:33 PM
brubble's Avatar
Re: 150 Shot
if you go to ls1tech.com and do a search there is a lot of good post on the install of that pump. you can also email racetronix and they will send you the directions. that and a haynes manual is all you need.
Old Feb 13, 2005 | 07:08 PM
T/A lt1's Avatar
Re: 150 Shot
I am just using a NOS booster pump along with with my stock intank pump, stock injectors, 10bolt and have run 10.20's@132mph! so you should be fine. The only trouble you may have is that 4L60. Goodluck. Later Clint
Old Feb 14, 2005 | 07:36 PM
"White Knight"'s Avatar
Re: 150 Shot
I'm going to be running my 10 bolt on a 150 shot this summer, i am more worried about the tranny as T/A lt1 has stated that is where you might have some problems eventually, depending on how early you spray.
Does that kit that sells for $219 come with the everything.....just seems like too good of deal MSRP is like $250. I migh be buying me one
Old Feb 15, 2005 | 09:21 AM
brubble's Avatar
Re: 150 Shot
yes thats the plug and play pump. that pisses me of thats $20 cheaper than i payed for mine, from them!
Old Feb 15, 2005 | 11:02 AM
Re: 150 Shot
Sucks for you......excellet for me
How hard was everything? Not the pump install (cause i know what that's like--cause i have done a couple intank ones), but hooking it all up--like the wiring and such-everything go together real nice and clean?
Old Feb 15, 2005 | 07:40 PM
MarkyMark's Avatar
Re: 150 Shot
What is more performances website address? I am thinking about getting a pump so I can spray a 150 shot safely.
LT14LIFE
Nov 15, 2015 06:22 PM
68camaroboltz
Oct 5, 2015 11:56 PM
Sep 18, 2015 03:46 PM
Sep 17, 2015 11:53 AM
NewsBot
Sep 15, 2015 11:53 AM
