100 shot, showing 4 degrees retard
Old Jan 8, 2003 | 08:00 PM
Hawk's Avatar
am i OK running the car like this?? I hooked up a scanner, on full spray with a 100 shot, the car pulls says it is using 4 degrees retard. At NA WOT, it pulls 0 degrees, it only pulls on spray. Also, my system seems to surge on spray, it like cuts alittle, is this due to my FPSS set at 39psi?? Should i set it lower?? Thanks, i just sprayed for the first time today, boy it was fun!!
Old Jan 8, 2003 | 10:43 PM
Fuels94TA's Avatar
If I remember it's 1-2 degree for every 50 h.p. It's better to run rich then lean. I wrote in your other post about your nozzle location. That surging you have was the same thing I had. Until I center the nozzle and made sure it's about 6 inch's from the T/B.
Vinny
Old Jan 9, 2003 | 12:01 AM
35thanniv.SS's Avatar
Run with some cooler plugs and higher octane gas
Old Jan 9, 2003 | 09:10 AM
Hawk's Avatar
i'm running tr6's(gapped at 0.038) AND 93 octane AND i have a accel 300+ digital ignition........ Should i try some race gas, and if it still knocks i know it's false right?? Thanks again.
Old Jan 9, 2003 | 09:14 AM
Hawk's Avatar
Vinny
i fixed the surging, i turned down the FPSS a bit........
But your point is taken on nozzle placement, but i would assume the fogger mists it so much it wouldn't matter, and the inrushing air would just disapate it anyway throughout the intake. Even the pics in the NX install guide have the nozzle coming in from the side, but yes, u do have a point, i'm just not sure how much of a diff it would make. THanks anyway.
Old Jan 10, 2003 | 02:01 AM
When I know im going to be spraying I always run with 103 octane just to be safe.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
slimdawson
Aug 25, 2002 10:10 PM
snksknr94
Aug 2, 2002 07:31 PM
MBonZ28
Jul 30, 2002 11:42 AM
