Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
RR question??
Old Mar 27, 2004 | 12:28 PM
2MUCHZ's Avatar
RR question??
Hey guys a just put a set of 1.6 rockers on my car but the stock valve covers will not work not tall enough.....did anybody else have this problem.....if so where did you find a set of tall style centerbolt valve covers......i tried converting a regular tall style Small block set but cant get them to seal properly.....thanks alot
Old Mar 27, 2004 | 12:31 PM
PhantomTA's Avatar
Moderator
Re: RR question??
you have to clearance the valve covers..
take a dremel and get to work
Old Mar 27, 2004 | 01:20 PM
Black Sunshine/ 00SS's Avatar
Jegs or Summit. Or just as he said above, and maybe try double gaskets.
Old Mar 27, 2004 | 02:24 PM
2MUCHZ's Avatar
thanks guys
Old Mar 27, 2004 | 07:01 PM
dreamer1q's Avatar
Hey PM me with a update on things.
Q
Old Mar 27, 2004 | 07:31 PM
IROC5.7TPI's Avatar
Theres a company out there that makes a shim that goes between the vc and the head to allow clearance with stock vc's. I'm sure if you look around you'll find what i;m referring to.
Old Mar 27, 2004 | 10:14 PM
97WRAITH's Avatar
I am using the stock covers with my 1.6 comp pro mags.You can bend the lip on the support ribs closest to the intake.Do a search on LT1 tech.There is a website with detailed pictures on how to do it.
Rob.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
