Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Looking for info on exhaust temps...>>
Old Aug 28, 2002 | 11:31 AM
MattSLONOMO's Avatar
Question Looking for info on exhaust temps...>>
what to expectfor sure at the primary tube
and collector..
both on motor and on spray(150-300 shot)..
10.5 to 1 LT1
Thanks ahead!!
Matt
Old Aug 28, 2002 | 03:15 PM
94_Z28_ragtop's Avatar
Post
Rob - That's true for turbo DSM's, but it might be different for a V8, especially on spray.
Old Aug 28, 2002 | 05:59 PM
Post
I wasn't sure which is why I said "might" be different
BTW Rob - I got the head for the Laser. It should be going back together this weekend. As soon as it's done it's going up for sale.
[This message has been edited by 94_Z28_ragtop (edited August 28, 2002).]
Old Aug 28, 2002 | 06:14 PM
imnotfast's Avatar
Post
Not going to say it happiens in a street car but seeing 1700°F 1 inch out of the head is normal in test cells. Have seen as high as 1900°F but not for extended times. We run one test where the exhust glows red from the head to the floor. Hope this helps you out some
Old Aug 28, 2002 | 06:22 PM
Hot Rod Hawk's Avatar
Post
Matt, Found alittle since we talked this afternoon.
http://www.bc-engr.com/faq_s.html
since looking around egt's refferance at the port, I "believe" the temp mentioned would be
"port".
still looking for for data down stream from ports. would ya say you have the probes 34" from the ports?
more:
http://www.revsearch.com/dynamometer...ninations.html
[This message has been edited by Hot Rod Hawk (edited August 28, 2002).]
Old Aug 29, 2002 | 09:41 PM
Talking
Matt, found some good info!
read it thru twice :wink:
http://www.superstockforum.com/showt...&threadid=2558
Firehawk...
Red...
Fast...
...You Better Pack a Lunch!
Http://home.earthlink.net/~runext/index.html
Old Aug 30, 2002 | 07:14 AM
Black Sunshine/ 00SS's Avatar
Post
I just saw some info on this in one of the magazines. I'll look for it.
Other than that, I can tell you that Dan Burke (board member) would be the most likely person that I know who would be able to help you.
Old Aug 30, 2002 | 01:45 PM
Post
<font face="Verdana, Arial" size="2">Originally posted by Hot Rod Hawk:
</font>
Great Info Broh!..
thanks for digging for me!!
..oh..
the probes are approx 35-36" down..
Thanks Again!
Later Broh..hope you're fee;lin' better!
Matt
Noct
May 26, 2016 10:26 AM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Queens94z28
Nov 20, 2014 06:03 PM
