Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Just bought another Camaro....
Old Sep 10, 2002 | 10:37 AM
  #16
derty's Avatar
Post
Sugar in the gas tank man! Get some fuel out and have it checked out. You could pull a head off and check the cylinders to see if they are all gummed up.
Old Sep 10, 2002 | 10:45 AM
  #17
Black Sunshine/ 00SS's Avatar
Post
If it is sugar, then that means replacing fuel tank, lines, motor, right?
Might have to part the car out... Damm
Did I mention the motor looks pretty?
Old Sep 10, 2002 | 03:20 PM
  #18
91 Redd Sledd's Avatar
Talking
I am glad I am not home right now.If ya gotta drop the tank it aint fun.You gotta drop the rearend down first. It isnt too hard depending on how rusted up it is.One thing is for sure.It sure is'nt fun.Have at er Harold. P.S. It can't be that bad those cars are pretty simple.If you need a lower end I have one at my mom and dads.It is a 305 with 88,000 original miles.If you wanted it you could have it.That way you would'nt have to part it out.You could get it ogether and sell it as a whole.Parts for those cars are cheap.They are a dime a dozen. Let me know cuz I'll tell ya where it is at exactley if you need it.
James
Old Sep 10, 2002 | 04:14 PM
  #19
derty's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Black Sunshine/ 00SS:
</font>
If it is sugar you have a helluva lot of work to do. Tank, pump, lines, reassembly of the heads (gotta clean them up), the lower end and hopefully it didn't get into the oil along the cylinder walls. I'm hoping that it isn't for that motors sake! But if you have to do all of that you might as well put in some minitubs on it!
Old Sep 10, 2002 | 11:54 PM
  #20
Thumbs up
I second Derty's vote for mini-tubs!!!!!
All in favor say I....... (Crowd in the backround unanimously mutters I)
Mini- tubs it is Harold.Keep us updated on your progress.
James
Old Sep 11, 2002 | 03:05 PM
  #21
limige's Avatar
Post
lol, pantera, rock on!!
yeah i picked one up last year, 86z minus drivetrain, tight body hardly any rust. i rebuilt a 305 and threw in the 700r4 but i haven't bolted the b&m shifter in yet and reassembled the interior, just need to go through the brake system and my winter car will be on the road!
debating a twin turbo kit for the 305 but i would rather get a aftermarket fuel injection kit first, as it is i'm not crazy about the edelbrock in the winter.
oh well one of many projects, get the 86 on the road and disassemble the 94. lol, what social life?!
Old Sep 11, 2002 | 03:26 PM
  #22
Talking
I have been painstakingly thinking since Sunday on what to call your third gen.If the 01 is Black Sunshine ( Actually Blacksunshine II) Then are you going to call the Third Gen "Black Mullet"????It's the best I could come up with.
Old Sep 11, 2002 | 06:05 PM
  #23
Post
Actually, the 01 SS is "Black Sunshine 3", I've had a 97 RS, and a 00 SS, all of them have been black.
I'm still debating on what to do. If I can get Andy to go over there with me, then perhaps we can figure something out.
The car isn't cherry, by any means, but it does not have one single spot of rust on the car. I'm not saying the paint is pretty, or that the panels are all perfect & straight, some are, some arent.
I wish you were here James, I would put your a$$ to work.. Actually, dropping the rear isn't that hard at all, but I suspect pulling the tank wouldn't be pretty. His brother told me today that there was some water in there. It had a lock on the tank, so how the hell could it get in there? Condensation? Injectors are most likely plugged up, from rust in the bottom of the tank? Would that make the motor run rough? It shook like hell when it ran, & sounded like knocking to me, but really wouldn't stay running long enough for me to concentrate on that.
If I can get it to run, it would be a low buck beater. So, no tubs.. No ZZ4, but I dam sure did think about that
Ok, going to start another post to get a survey on a name... Submit your request..
Old Sep 12, 2002 | 08:18 AM
  #24
IROC5.7TPI's Avatar
Post
Turd Gen Troubleshooting- Part I
Check fuel pressure at the rail. It should be 39PSI with the vac hose on and raise when the hose is popped off.
Check for spark. Sometimes the pickup in the distributor will cause the problems you're talking about.
Is there a Check Engine light on? If so, jump the top two terminals on the right in the ALDL connector with a paper clip. Turn ign. to "on" position. Watch Check Engine light. It will flash a code. One blink, then two blinks- indicating a code 12 which is diagnostic mode. It will flash each code 3 times starting with the aforementioned 12, then after all the codes are flashed it will flash a 12 again signaling the end of the code retrieving sequence.
If you have codes, post them here and I will try and help you with them. This sounds like a much simpler problem than your making it out to be. Take the scientific approach. DIAGNOSE IT RIGHT!
Mike L.
1987 IROC Z 5.7 TPI A4 3.27 Borg-Warner four wheel disc
Mods:
2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified airbox w/ K&N's, Relocated MAT sensor, Gutted MAF, 160* thermostat, MSD 6A, Accel 8mm Wires, bypassed TB coolant, 3" Flowmaster 3 chamber single outlet, custom adjustable cutout, 3" MAC mandrel intermediate, airfoil, ported plenum. !smog, Crane AFPR, Accel rail mounted FP gauge, Harlan shiftlite, 24lb. injectors, Hedman headers, a few others I forgot...??? FINALLY GOT PAINT!!
Check out my IROC webpage!
jasonduaine
Apr 1, 2015 08:09 PM
grabbem88
Mar 25, 2015 12:09 PM
95chwagon
Feb 28, 2015 12:02 PM
99TransAmWS6
Jul 26, 2002 03:18 PM
