Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Help! who knows alot abot Mustangs
Old Jul 9, 2003 | 01:58 PM
Joe_88_fiveO's Avatar
My car is lope-ing and I have no cam. Well at least the guy who sold it to me didnt say so. I have a m5 it idles at 900 but at times it will lope down to 500 and back up to about 900-1000. Once i hit the gas it will go back to normal at 900. Help is it the wires? Am I getting enough spark? The wires are stock. Is this a rotor/distributor problem b/c this weekend I'm going to do a full oil and tune up- wires and the whole nine. Thankz FiveO
Old Jul 9, 2003 | 03:10 PM
scott9050's Avatar
Rolling idle is a common problem, and the fix takes about 5 minutes. The Idle air control valve on the side of the throttle body often gets stuck because of carbon deposits. Simply unscrew it into 2 pieces (take the 2 screws out) and take some carb spray cleaner and clean the pintle. That is probably where the majority of the problem is coming from. While you are there give the throttle body a good cleaning too. This should solve the problem.
Old Jul 9, 2003 | 03:12 PM
scott9050's Avatar
Originally posted by Killerjello
its a ford, thats your problem....... dont you know you gotta fix or replace daily????
I have a ford ranger beater that does that though, the idle jumps up and down quite a bit, its some sensor screwed up, forgot which one, im too cheap to replace it.
Do the same thing that I said below.
Old Jul 9, 2003 | 06:12 PM
millhouse's Avatar
Yep, that's what I did for mine, and it hasent done it since. It made it a pain to run the a/c, as it was prone to stalling at a stoplight with the idle dropping to low.
Btw, q-tips work great, and I think I went through a good 50 of em'.
You can also try cleaning the maf sensor with a little rubbing alcohol and some q-tips. Be careful though, as the wire is very delicate and the q-tips sometimes shred on the sensor. Just take your time and it's really not diffacult.
Daluchman1974
Sep 11, 2015 06:12 AM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
colts0455
Jul 20, 2015 09:52 AM
NewsBot
Jul 8, 2015 06:47 PM
