Middle Atlantic New Jersey, New York, and Pennsylvania
Time to beg for help
Old Jan 18, 2008 | 04:49 PM
  #16
1SlowFormula's Avatar
Originally Posted by Schweet97Z
IF i can find my spacer, you can have it, its brand new....but i know Jay hates the solid spacer
I was always told that the solid spacer helps cut down on them getting noisey over time, if he doesn't like them that's cool too since most install kits I have been looking at have the crush sleeve anyhow...
Old Jan 19, 2008 | 10:35 AM
  #17
86T/AWS6's Avatar
I cant speak for Harold but the 4.10's i did in my original 10 bolt never got any louder after break in and i used a crush sleeve. My 4.10s did eventually break but not because of strength or set up, its a long story but basically richmond recommended some grinding on 4 of the ring gear teeth to clear my posi unit and those 4 teeth eventually broke off...
The only reason i dont like the solid spacer is because it is very hard to get an acceptable bearing preload, add a shim and its way to tight take one out and its not enough...thats how harolds was when i was setting his up. If we end up doin your rear we could always try it and if its being a b!tch like harolds was there is always the crush sleeve...I never heard the opinion that the solid keeps them quieter longer, most say it just adds some strength.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Feffman
Oct 9, 2015 05:42 AM
bossco
Nov 29, 2014 10:18 AM
formula79
72
Jun 29, 2002 08:18 PM
