ZZ-9, ZZ-9x, Hot cam????
Old Feb 20, 2003 | 09:29 PM
showtime89's Avatar
ZZ-9 or Hotcam
Well I have been set on the LT4 hotcam for a bit and was going to do it over spring break(mid april). But now I am looking at TPIS's ZZ-9 cam and the specs are similar to the hotcam. The cam along is $375 and requires springs that some people apparently have got for free with some haggling with TPIS. The ZZ-9 is designed to run with the stock RR's and the hotcam kit includes the 1.6's. So I was thinking maybe do the ZZ-9 and then the RR's at a later date, OR maybe even the ZZ-9X which is a much beefier cam for also $375 and that's a bigger cam than the Hotcam #'s wise even before the RR's. I am gonna call TPIS and see what they say, but I was looking for your guys opinions on those two cams for everyday driveability.
Here are the #'s for the cams.
Hot cam 1.5 RR's
279/287 218/228 492/492
Hot Cam 1.6 RR's(kit)
278/287 218/228 525/525
ZZ-9 1.5 RR's
282/287 212/226 483/520
ZZ-9X 1.5RR's
287/290 225/240 525/558
Also, if someone could give me the numbers for the ZZ cams with 1.6 RR's
Next winter should be doing heads/shortie headers(warranty still works this way)
Here's the link for the TPIS Cams
P.S. Sam taylor hotcam kit, $470 to your door.
P.P.S. How does Florida's emissions checks work? Visual, sniffer, none?
I may end up in Jax or Orlando come fall.
Old Feb 20, 2003 | 09:46 PM
95BLKTA's Avatar
FL doesnt have emmisions testing
PS Sam Taylor has been backordered on the hotcam kit for awhile
GMPartsdirect.com has the hotcam kit in stock and its not too much more(not enough to matter anyway).
i just ordered the kit and an LT4 Knock module for under $520
shipped
Chris
Old Feb 20, 2003 | 10:01 PM
showtime89's Avatar
If I order it(hot cam kit), it will be March 15th, and I won't need it till April 12th.
jj_burchiel
Mar 5, 2015 07:05 AM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Smokn '94 Z
Aug 4, 2002 06:11 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
