yet another LT1 miss at high rpm thread
Old Sep 18, 2004 | 12:15 AM
Fux0redImages's Avatar
i dunno, maybe someone will know. my friend has a '94 Caprice 9c1, LT1 equipped. under heavy, consistant load or high rpm, it hesitates. he changed the plug wires tonite, and though it isn't nearly as bad as it was before, it still hesitates up high in the rpm. think a coil could be a quick fix?
Old Sep 18, 2004 | 06:12 AM
ASTROJOE LT1's Avatar
Re: yet another LT1 miss at high rpm thread
I had the same problem untill this past weekend. I swapped in another coil I had and "Presto" the high speed miss is gone. It is worth a try on your part.
Old Sep 18, 2004 | 06:49 AM
TobyZ28's Avatar
Identical problems - Coil swap fixed it.
Noticed arcing off the bad coil when it was dark (VERY little but you would see occasional flashes)
Old Sep 18, 2004 | 10:14 AM
1995greenTA's Avatar
I had the same problem, but i went from running 87 to 93 octane, which made a big difference, and then changed my plugs and wires, which terminated the miss. good luck
Old Sep 18, 2004 | 12:34 PM
WhyHelloOfficer's Avatar
Ditto
I just did that no more than three weeks ago. Runs like a champ now
-Joe
Old Sep 18, 2004 | 06:50 PM
no dice. changed the coil, same problems. tomorrow i'm going to check/change spark plugs and possibly change the ICM
rideordie
Nov 5, 2019 04:52 PM
HectorM52
Jun 23, 2016 08:42 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Camaro90RS
Jul 23, 2002 07:57 AM
