y-pipe hits floor when under power
Re: y-pipe hits floor when under power
hmmmm... Find the oppurtunity and purposely get hit by some lady not paying attention (thatll be easy)
Prove it was her fault.. get free repairs on her tab
sew for personal injuries and traumatic stress
buy more mods! and a fixed y-pipe problem!
Its genuis!
yes i know i spelled sew or whatever it is wrong...
Its genuis!
I tried every trick you guys listed and didn't work. Poly's w/ a silicone sandwiched and it worked temporarily. You really want to fix it? Spend 60-70 bucks and buy some solid motor mounts. You won't have this problem ever again.
It is probably hitting the brace that runs from the rocker panel to the tranney mount.
I took and cut the sides out of it where the collector passes and bent the bottom up to the floor and rewelded it. Now I got plenty of room. After some grinding,sanding,and paint ya can't hardly tell it. This will give ya 3/4" more clearance.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
grabbem88
Mar 18, 2015 01:25 PM
