XE230/236 and emissions
Old Nov 13, 2003 | 03:14 PM
Droff's Avatar
Can a good tuner make the XE230/236-114 pass emissions? Or, has anyone passed the snifter on the XE230/236?
Old Nov 13, 2003 | 03:28 PM
gb95zconv's Avatar
I passed....
Old Nov 13, 2003 | 03:31 PM
WheelmanZ28's Avatar
wow, interesting. I didn't think a cam with such lift numbers would pass. I'm gonna definitely consider this cam now
Old Nov 13, 2003 | 03:32 PM
Droff's Avatar
Cool..
You have ported heads etc.? Also is your LSA 112 or 114?
Old Nov 13, 2003 | 03:37 PM
gb95zconv's Avatar
Yes ported heads.....it is on a 114 lsa which helps.
Old Nov 13, 2003 | 04:05 PM
FacelessZ's Avatar
what about a .112?
Old Nov 13, 2003 | 04:40 PM
dnz28's Avatar
I bombed with the 112 but I also have gutted my cat.
Old Nov 13, 2003 | 04:59 PM
FacelessZ's Avatar
Think it would pass with a high flow cat?
Old Nov 13, 2003 | 05:08 PM
NiteRider's Avatar
Wow!! Obviously you won't pass without a cat. Hmmm, this brings new hope! Did you have a EGR? Also what headers, any other data, did you do any slight changes in tune, timing, temp, etc... Let me know please.
Old Nov 13, 2003 | 05:59 PM
dnz28's Avatar
I have no emissions at all no egr, no cat. it will pass with a cat though. my friend passed with a cc306. just do a tune up before you go. Also my programming was done by pcmforless and i told him to run it fat and he did. so run it lean you'll make a clean getway.
Old Nov 15, 2003 | 08:47 AM
gb95zconv's Avatar
! AIR. ! EGR....its not needed with the overlap. Hooker shorties with stock cat. Idle RPM 1000. No tuning changes other than increasing the rpm at idle from 900 to 1000. Temp was 195.
Old Nov 15, 2003 | 11:33 AM
marshall93z's Avatar
you also have a 383 though too right? that makes a difference...
Old Nov 15, 2003 | 02:18 PM
gb95zconv's Avatar
Yes...I have a 383, but it should pass in a properly tuned 350.
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
CARdiac
V6 Tech
11
Oct 20, 2002 06:52 PM
jgeorger
New England Area
15
Sep 8, 2002 09:50 AM
