Fan fuse keeps blowing???
Old Nov 15, 2003 | 01:29 PM
JuiSSed's Avatar
it's the same 25amp fuse for the fan that keeps blowing.. where can i start my search for a fix?
thanks
vinnie
Old Nov 15, 2003 | 02:03 PM
mikeRv6's Avatar
Same thing has been happening to me, except my fan fuse is a 10 amp, that year is your car?
You live in NYC? That’s funny because my fuse blew yesterday on Canal Street, then again on Flushing Ave in Brooklyn this morning. Then once more on the BQE, it sucked. Where do you live?
Apparently the fan fuse is connected to other systems in the car. Skip shift and reverse lockout, also the o2 sensors, EVAP canister, some others I think. One of these other systems is probably failing and causing the problem.
I found out that my reverse lockout solenoid went bad and is causing the fuse to blow, which is disabling my fans. Now I just have to figure out it the solenoid is bad, or if it’s a wiring problem.
Good Luck
Old Nov 15, 2003 | 02:10 PM
JuiSSed's Avatar
i live in Queens... my front o2 are bad, causing the check engine light to come on.. i dont know if that can cause the problem, but i'll have to change them to find out.. i have a 96
thanks
vinnie
Old Nov 15, 2003 | 02:21 PM
RangerBob's Avatar
Airpump. Should be covered under the recall.
Bobczar
Oct 23, 2015 11:22 AM
colts0455
Jun 30, 2015 05:17 PM
Zuvell
May 15, 2015 08:18 PM
4586
Apr 27, 2015 06:08 AM
Fusion93Z
Jun 14, 2002 06:16 PM
