XE 236/242 dyno #'s
Old Jul 22, 2003 | 02:38 PM
  #31
ltlhomer's Avatar
No doubt you saw those #'s. They are typical dynojet inflated numbers.
Launching better and what not might affect the et's, but not so much the trap speeds.
And none of that changes the fact that dynojets inflate hp numbers.
Old Jul 22, 2003 | 09:12 PM
  #32
Dan K's Avatar
OK...so where do we start the mustang dyno vs dynojet thread?
Or where can I get info on both in order to make my own decision?
Old Jul 22, 2003 | 10:26 PM
  #33
brain's Avatar
Lt1homer, how much does your car weigh? You say that mustang dynos are correct, and dynojets are inflated, but with your e.t. and mph, your car must be especially light. I have a calculator that hasn't failed me yet, then again, it could be setup for inflated dynojet hp numbers. Also, I believe that Fred has done an engine dyno and a chassis dyno and with an auto it showed a 13% drivetrain loss. Seems kind of conservative even.
Old Jul 22, 2003 | 11:13 PM
  #34
ltlhomer's Avatar
My car is full weight minus roughly 150 lbs (backseat, pass. seat, ac stuff) and it's a t-top car. And that trap is with tranny not going 2-3 w/ me having to let off the then get back on it. I expect 115 traps this weekend w/ a rebuilt tranny and et streets (w/ the additional weight of a 6 point cage and sfc's to boot). Wait til the cool weather comes, I might even see 116-117 a few times.
The guys at detroit speedworks said my car w/ those hp numbers should trap around 113-115 (using their calculator) and it was right on. In all seriousness, you probably are using a calc. meant for dynojet numbers because that is the industry standard (probably because they are much cheaper to buy and most shops don't want to fork the extra cash for the MD's). Put in 390 and tell me what you get, because I've heard MD's read roughly 12% lower than dynojets and 12% + 350 is right about 390. Catch ya later guys...
Old Aug 14, 2003 | 01:46 PM
  #35
AlexsZ's Avatar
Like it was mentioned, 73rwhp isnt too shabby..and I know there is a lot more in it after I get it properly tuned and my tranny fixed.
So far, opti/plugs/wires are all in great condition...replaced all but the opti during the rebuild, adn the opti only has about 6months of use prior to deploying for 5 months..sooo, about a year old.
Once I get my tranny done, I can tune properly...untill then, I've gotta settle for a measly 353rwhp
Old Aug 14, 2003 | 02:05 PM
  #36
Gripenfelter's Avatar
I'm not entirely convinced this XE 236/242 cam is the best for LT1s. I see guys with XE 230/236s putting out more hp.
Old Aug 14, 2003 | 07:40 PM
  #37
REPO's Avatar
I am not sure........I managed a 11.43 @ 127 with mine, and a bit of juice.
Old Aug 14, 2003 | 07:58 PM
  #38
Smokn '94 Z's Avatar
Arrow
Alex. Never set your expectations to high when your looking for a #. I am learning that, right Dan K? Anyway that 73 rwhp is very respectible IMO & these LT1's are very inconsistant with each other when comparing to each others. You will squeeze out a bit more HP but just get it to the track to get some real #'s. That is where the bragging is. I gave up on trying to become a dynoqueen..... I want 11's & will get them!! That is what it is all about. 1/4 mile at a time...
Good Luck
fift5
11
Oct 1, 2015 10:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
Strick
Jul 14, 2015 07:28 AM
