XE 224/230 and pushrods
Old May 19, 2003 | 02:33 AM
QCKZ28's Avatar
ok this will be my setup: heads ported by lloyd with oversized intake valve (2.00), springs for the XE 224/230 lift on 1.6RR (.536/.544), im using the impala head gasket 0.29. my question is will the stock pushrod lenght work?
jesse
Old May 19, 2003 | 05:39 AM
rskrause's Avatar
Moderator
I don't see why not, but the only way to tell for sure is to look and see that the tip of the roller is ~in the middle of the valve stem tip at mid lift after the heads are installed. You don't specify the springs you are using or high you you plan to spin the motor, but you might consider some HD pushrods anyway,
Rich Krause
Old Aug 31, 2003 | 06:52 AM
pu12en12g's Avatar
For what it's worth... the stock length pushrods did not work with my setup. I supposedly need 7.400" pushrods.
I have the XE 224/230 and TPIS AFR 190 heads, 1.6RR, Impala Head Gasket.
Old Sep 1, 2003 | 07:54 PM
QCKZ28's Avatar
with my setup stock pushrods ending up working fine. ported LT1 heads, impala gaskets, xe224/230.
Old Sep 1, 2003 | 08:15 PM
Fastbird93's Avatar
Stock length pushrods working fine on mine too. Stock heads milled .005" and stock GM gaskets.
Old Sep 1, 2003 | 09:06 PM
ddr698's Avatar
I have AFR 190s and comp cams extreme energy cam and had to go with 7.4s as well.
13qtr
Oct 28, 2016 08:11 PM
Quickss96
Jan 29, 2016 05:56 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
94Form
Jul 17, 2015 10:56 PM
