xe 224/230 guys...
Old Jan 23, 2004 | 07:46 PM
1.8ttolt1's Avatar
xe 224/230 guys...
are you guys experiencing cam surge in first or second gear driving at low speeds such as in a parking lot etc.? it is a bit annoying. just wanted to know if it was just my car. and its not the car wanting to stall from too low of rpm's. i've experienced surging in turbo cars and it feels just like that.
Old Jan 23, 2004 | 07:54 PM
Wild1's Avatar
Would programming help?
Old Jan 23, 2004 | 07:57 PM
trax's Avatar
I had just a hint of surging in 1st gear, but that was when I was first learning stick and I would occasionally bog the car down to about 900 rpm in parking lots. As long as you can keep it at around 1200 or so it should be ok.
1.8ttolt1's Avatar
i have programming from pcmforless, and i didn't experience any surge until i put in the programmed computer.
Old Jan 23, 2004 | 08:01 PM
1.8ttolt1's Avatar
right now my idle is set at 900-1000 rpm's and very rarely do i bog. i usually slip the clutch and keep the revs up, but around 1500 it'll buck and surge a little until i gas it and keep the revs around 2000
Old Jan 23, 2004 | 08:05 PM
Wild1's Avatar
I also toss this question up in the Computer Programming section. There may be one thing that wasn't re-programmed. If you do find out, let us know on this tread too...
Old Jan 23, 2004 | 08:14 PM
1.8ttolt1's Avatar
maybe a mod would move this over to the programming forum. i know they don't like x-posting.
LimitedEd1LE
May 18, 2015 01:24 PM
Rodrigues
Mar 11, 2003 11:24 AM
Javier97Z28
Mar 5, 2003 09:52 PM
sc93
Mar 5, 2003 05:56 PM
stanghunter211
3rd Gen / L98 Engine Tech
Dec 7, 2002 08:26 PM
