XE 224/230 and CMotorsports Stage II heads ... dyno results
Old Jan 10, 2004 | 10:36 PM
  #16
unTAmedLS1's Avatar
I think it depends on your heads cuz I peaked at 6300 so I wouldnt make such a generalization
Old Jan 10, 2004 | 10:42 PM
  #17
Fastbird93's Avatar
Here is my dyno chart. Looking at it, it was just starting to flatten out at about 6K. I was obviously getting a little too lean to continue higher. Once I get everything sorted out, I'm expecting to make good power up to about 6300-6500. The TQ doesn't fall off as quick as bigger cams either, which is definitely a plus.
Old Jan 10, 2004 | 11:19 PM
  #18
got_hp?'s Avatar
Originally posted by LT1ponykilla
So you guys think we may need new injectors? If so, I will get some before I dyno my car after the heads.
yeah most likely............running injectors over 85% duty cycle is not a good idea........and yours are definetly over that if youre making more than 360ish rwhp in an lt1.
Old Jan 11, 2004 | 01:04 AM
  #19
LT1ponykilla's Avatar
Wheres the best place to get injectors. I may do that at the same time I do my heads. Thanks.
Old Jan 11, 2004 | 07:05 AM
  #20
trax's Avatar
I will definately have to look into injectors. I had planned to do some fuel system stuff over the winter (like an LS1 gas tank swap) but I never got a reply from the guy selling me his tank... just went ahead and bought swaybars.
I don't have any info on what the injector duty cycle is on my motor. I know in general you should run the smallest injector you can get away with and still have a safe margin of duty cycle up top... until I can AutoTap the car, are there any guesses as to what size I should look at?
Old Jan 11, 2004 | 11:25 AM
  #21
got_hp?'s Avatar
this ford place sells them for a great deal...........also, you can get them from guys on the mustang forum (corral.net or something) for really cheap.
Old Jan 11, 2004 | 11:38 AM
  #22
This may sound like a dumb question, but will those fuel injectors for a Mustang work on a LT1?
Old Jan 11, 2004 | 12:07 PM
  #23
Fastbird93's Avatar
Those are SVO injectors. They work just fine in our cars. Both of mine are running them, as well as a complete plethora of others out there.
Old Jan 11, 2004 | 12:45 PM
  #24
Thanks.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Vinceocratic
Jan 26, 2015 09:26 AM
importkiller94
Jan 17, 2015 09:03 PM
1LEThumper
Jul 14, 2003 12:45 PM
