XE 224/230 and CMotorsports Stage II heads ... dyno results
Old Jan 9, 2004 | 04:15 PM
trax's Avatar
Cool XE 224/230 and CMotorsports Stage II heads ... dyno results
366.8 rwhp
351.5 rwtq
The dyno sheet
My setup, in a nutshell:
Combination Motorsports Stage II heads
Comp XE 224/230 cam (.536"/.544") 112 LSA
Hooker LT's, Mufflex Y, Hooker catback
GMPP CAI, trickflow elbow, 52mm TB
T56, Stock 10-bolt with 3.73's
Torque was a couple ft-lbs lower than I expected but other than that I'm pretty satisfied
Old Jan 9, 2004 | 04:35 PM
93Z286Speed's Avatar
is that on a stock fuel system?
Im doing something very similar..
hopeing for around those numbers
Old Jan 9, 2004 | 05:00 PM
got_hp?'s Avatar
thats a really nice flat torque curve
but i was expecting higher peak hp by about 20 or so.
what size injectors?
Old Jan 9, 2004 | 05:03 PM
trax's Avatar
Fuel system is stock from pump to injectors.
Old Jan 9, 2004 | 05:05 PM
Chris 96 WS6's Avatar
Good numbers. I have the same cam but on a 114LSA and did 362hp with Lloyd's big valve heads.
You might want to check your injector pulsewidth though, unless you've jacked up the pressure. I was running stock fuel system with SVO 24 lb injectors and hitting like 99% duty cycle at 6000 rpms. I upgraded to 30's and I have plenty of injector left to grow into
Old Jan 9, 2004 | 06:06 PM
got_hp?'s Avatar
ouch.........id be scared of those stockers locking up or something.........im sure theyre at 100% duty cycle!
new 30lb FMS injectors are only $199, why not get a set?
Old Jan 10, 2004 | 04:18 PM
96LT14u2Nv's Avatar
NICE!!!!!
Old Jan 10, 2004 | 04:20 PM
snksknr94's Avatar
That seems kinda low to me, but maybe it's just me. As long as you're happy with them.
Old Jan 10, 2004 | 05:47 PM
Fastbird93's Avatar
Good numbers. I'm running the same cam with different heads, and made 375/363 with about the same powerband your graph shows.
How was your A/F graph, if you did it?
Old Jan 10, 2004 | 06:42 PM
LT1ponykilla's Avatar
Those numbers arent to bad. Im hoping to make around there after I get my heads done. Only time will tell.
Old Jan 10, 2004 | 06:44 PM
ibanez6rg's Avatar
Yea, I'd upgrade to some 30lb injectors. Those injectors are pretty much maxed out if they aren't already.
Good numbers though!
Old Jan 10, 2004 | 06:46 PM
TQ started dropping off kinda early or is it just me?
Old Jan 10, 2004 | 06:50 PM
jmzlt1's Avatar
How do you find out the duty cycle of injectors? I'm using 24lb svo's and I've tried to use the scanmaster but the numbers don't add up right. That dyno graph looks just like mine except mine peaks at 5700 rpm. Nice numbers, though I thought that cam would net a little more than mine. You should check the duty cycle of your injectors to make sure they aren't holding you back. I don't even know if mine are.
Old Jan 10, 2004 | 06:58 PM
So you guys think we may need new injectors? If so, I will get some before I dyno my car after the heads.
Old Jan 10, 2004 | 09:45 PM
BPS's Avatar
BPS
Nice
That XE cam sure falls flat after 6K
