WTF (a4 issue)
WTF (a4 issue)
Was under my car today spraying some paint on the welds from my SFC install. And i noticed a black dot on my trans that looked like a hole. So I go for a look, and there it is. Its a small jab or hole almost about the size if you stuck a pencil through a piece of paper.
Its right at the very bottem of the plate that covers the torque converter, infront of the trans pan. I think its called the inspection plate? But it must of happend going over somthin on the road. Well I back the car off the ramps. Let it sit, and warm up. Then check the fluid. Trans fluid was at normal levels.
Is there any fluid contained in that area? I dunno if I should go order a new one. Or just patch it up?
Thanks,
Mike
Thanks,
Mike
Magenta_Hearts
Mar 25, 2015 10:24 AM
MadKilla
Jul 22, 2002 06:42 PM
