WTF (a4 issue)
Old Jun 5, 2004 | 11:19 PM
aintno6's Avatar
WTF (a4 issue)
Was under my car today spraying some paint on the welds from my SFC install. And i noticed a black dot on my trans that looked like a hole. So I go for a look, and there it is. Its a small jab or hole almost about the size if you stuck a pencil through a piece of paper.
Its right at the very bottem of the plate that covers the torque converter, infront of the trans pan. I think its called the inspection plate? But it must of happend going over somthin on the road. Well I back the car off the ramps. Let it sit, and warm up. Then check the fluid. Trans fluid was at normal levels.
Is there any fluid contained in that area? I dunno if I should go order a new one. Or just patch it up?
Thanks,
Mike
Old Jun 5, 2004 | 11:22 PM
If it is on the thin, sheet metal cover, you don't have to worry. It is just an access cover to the torque converter/flexplate. Put some JB Weld on it.
Old Jun 5, 2004 | 11:23 PM
ibanez6rg's Avatar
That's just to keep dust/dirt off of the flywheel (the cover). You're fine, all the covers have that hole in them.
Old Jun 5, 2004 | 11:38 PM
aintno6's Avatar
Oh so that wasnt a puncture ?
I was worried because there was small dent there. So figured somthing made the mark.
Thanks guys.
Smokn '94 Z's Avatar
Thumbs up
It's all ok Mike. I believe the hole is probably a drain hole for water to escape when driving in wet conditions....
Old Jun 5, 2004 | 11:39 PM
Oh yeah. If the hole is right in the bottom, middle, it's supposed to be there.
timmy39120
May 2, 2015 05:12 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Cam's maro
Mar 24, 2015 08:09 PM
jthomas
Sep 6, 2002 03:18 PM
MadKilla
Jul 22, 2002 06:42 PM
