Differences between exhaust 95 and 96??
Old Jun 5, 2004 | 10:07 PM
JDMZ28's Avatar
I know in 96 they put the dual cats on but what are the other differences between a headers system for a 95 compared to a 96?
Old Jun 5, 2004 | 10:15 PM
Dave89IROC's Avatar
96 has 4 o2 sensors
cats are way different
Old Jun 5, 2004 | 10:17 PM
)2overt SS's Avatar
Originally posted by Dave89IROC
96 has 4 o2 sensors
96's don't have four O2 sensors
Only two front ones in the manifolds.. and one rear one after the cats.
Old Jun 5, 2004 | 10:21 PM
JDMZ28's Avatar
So if I got a set of headers for a 96 they would work in my 95 huh? I don't have a cat either.
Old Jun 5, 2004 | 10:26 PM
Spinner's Avatar
Er, yes they do. Two in the front and two behind the cats. You've been grossly misinformed
Old Jun 5, 2004 | 10:29 PM
JDMZ28's Avatar
spinner is right
Dave89IROC's Avatar
the 96 V6 has 3, but the LT1 has 4
Old Jun 5, 2004 | 10:37 PM
)2overt SS's Avatar
I'm doing my headers right now.. I removed all my old exhaust... I only disconnected 3
Two in the manifolds.. and one that went in after my cats... wtf?
Edit: Anyone have pics of a stock 96 SS exhaust? Maybe Canadian ones are different??
Old Jun 5, 2004 | 10:59 PM
JDMZ28's Avatar
come on guys whats up.
Old Jun 5, 2004 | 11:18 PM
Depends on the type of headers and the y-pipe used.
Old Jun 5, 2004 | 11:32 PM
Lost's Avatar
The engines are both LT1's so any manifold that will bolt up to a 96 will bolt up to a 95 and vice versa. Most have o2 sims in place of the rear o2 sensors or have the rear ones programmed out (I did this) and so that takes care of that. Basically, if you don't care about emissions then any manifold will be fine.. now if you plan on bolting those headers up to a stock exhaust system you'll have to buy the appropriate y pipe.. but I'd say that you should ditch all the stock tubing if you're gonna install headers.
Old Jun 5, 2004 | 11:39 PM
JDMZ28's Avatar
thanks, yeah I'm going to custom bend a set of duals.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
3TAS4ME
Apr 15, 2015 02:24 PM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
