would these mods actually be good
Old Nov 1, 2005 | 05:17 PM
redington's Avatar
ok guys i was wondering about how much more hp i could get from the following mods Whats your opinions?
meziere electric water pump
roller rockers (dont know what ones to get)
pulley(s) (any of them actually make hp?)
air foil
TB Bypass
what are some other ways to get hp w/o doing heads and cam and nitrous? I have the following
93 z 28 M6
SLP CAI, Trick Flow Elbow, 160* stat, Pacesetter Long Tubes, 3" ORY no cats, SLP Loudmouth, AIR!, EGR!, Strange 4.10's
Old Nov 1, 2005 | 05:24 PM
96flame's Avatar
Re: would these mods actually be good
I would guess all of the above would be good for 30RWHP. Most guys claim 10 for EWP, I saw a guy remove his belt on the dyno and pick up 15 RWHP so I'd guess the pulley would be worth at least 5 RWHP, don't know about RR's cuz most times there done with a cam swap, airfoil probably not much but every bit counts
Old Nov 1, 2005 | 07:33 PM
bowtiethunder's Avatar
I would get a fan switch or do like I did and make your own if you haven't already. Maybe desensitize your knock sensor if getting false knock. I've read some good things about mail order tune also.
Old Nov 2, 2005 | 08:40 AM
redington's Avatar
i will look into the fan switch
-mike
Old Nov 2, 2005 | 09:09 AM
Bersaglieri's Avatar
meziere electric water pump or CSR generally worth 10rwhp/10rwtq
roller rockers (dont know what ones to get) GMPP/Crane work, but Pro Mags arent limited as much on lift. between 8-15rwhp
pulley(s) (any of them actually make hp?) ASP 23% Crank Replacement, I wouldnt waste money on any other
air foil
TB Bypass Free, do anything free for HP
You can always shave weight for a faster car. You might need some suspension mods or wheels/tires to get the extra power to the ground. A PCM tune from Madolf (ION) wouldnt hurt. After all the bolt on's your looking at cams and other power adders.
93 z 28 M6
-Dustin-
Old Nov 2, 2005 | 09:28 AM
There's a website with several of those mods dyno tested:
http://www.ws6.com/mycar.htm
Old Nov 2, 2005 | 01:22 PM
1995greenTA's Avatar
How about a mail order tune? I Thought it was well worth the money.
Old Nov 2, 2005 | 03:38 PM
2000GTP's Avatar
I couldn't agree more, for the little over a hundred dollars you'll spend on a mail-order tune,you should be more then happy with the results.
737drivr
Feb 20, 2015 12:00 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
