Would low voltage alternator cause low fuel pressure?
Old May 30, 2003 | 12:02 PM
BAD 97 WS-6's Avatar
The only thing still stock on my 247,000 mile WS6 is the Alternator. I know for a fact its putting out low volts because my windows go up really slow now, and the battery meter fluctuates a lot. Could this cause my low fuel pressure problem?
Old May 30, 2003 | 04:49 PM
Since the pump is an electric motor, lower voltage should result in lower pressure. The pump requires a pretty good amount of juice.
Old May 30, 2003 | 06:12 PM
Could this be the culprit?
Old May 30, 2003 | 06:32 PM
If it is not putting out the voltage it should, you are going to want to fix it anyway, aren't you? That will keep you from having other voltage related problems and maybe fix the pressure situation, too.
Old May 30, 2003 | 08:27 PM
Yeah, I need to get it fixed...just been lazy I guess.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Gtpguy
Jan 26, 2015 04:50 PM
Jul 4, 2005 05:00 PM
