would longer lower control arms help traction?
Old Jan 28, 2004 | 03:59 AM
billsbird's Avatar
...I am going to make my own lower control arms. If I made them longer would this help traction? .... Bill...
Old Jan 28, 2004 | 04:34 AM
texasTA's Avatar
More than likely not, since the engineers at Chevy put many hours into designing and perfecting suspension geometry. I doubt using a longer LCA would benefit anything, because you would also obviously have to lengthen the driveshaft, which in turn will push the rear end further back, which then would make the rear tires not fit in the factory wheel wells. But, I would believe the answer is the only thing it would do is cause a ton of problems.
DarkKnight
Buyer/Seller Feedback
May 4, 2015 03:32 PM
R@mpage
Apr 20, 2015 10:02 AM
thenewkid
Apr 12, 2015 07:42 PM
sseeya
Apr 9, 2015 06:38 AM
thenewkid
Nov 27, 2014 09:41 AM
