would I get SES?...
Old Jul 13, 2004 | 08:41 PM
Kurt Crosbie's Avatar
would I get SES?...
Wouldn't I get an SES light if my fuel pump was bad or the injecter were?
Old Jul 14, 2004 | 06:42 AM
If an injector has an electrical problem, you will get DTC 18 - Injector circuits. If the injector is plugged or sticking, it will not set the DCT 18 code, but might cause problems with O2 sensor "lean" or "rich" codes.
There is no way for the PCM to know the fuel pressure, so there are not codes for the fuel pump itself. Again, excessive pressure or inadequate pressure in closed loop is going to throw off the long term fuel corrections, and if they max out, they will set a code for "rich" or "lean".
Old Jul 14, 2004 | 04:07 PM
What about if my catalytic converter is bad?
Old Jul 14, 2004 | 04:11 PM
Again, there is no code specific to the catalytic convertor on a 1995. If it was not working - dead catalyst - there would be no consequential code. If it was "plugged" and restricting engine performance, it might remotely cause an incidental O2 sensor code, but I doubt it.
94Maroz28
Oct 27, 2015 04:38 PM
drt
Sep 27, 2015 04:39 PM
greenzee28
Sep 25, 2015 04:29 PM
MDZ28
11
Sep 24, 2015 09:15 AM
