would i get a code?
Old Jul 25, 2003 | 08:09 AM
Bobbys_97_Z28's Avatar
would i get a code?
would i get a code if my o2's are bad??i mean...im getting poor gas milage, but also i have a slight hesitation
Old Jul 25, 2003 | 08:18 AM
If they are bad enough, yes.
Monitoring it with a scan tool should tell you if they are operating ok. Check easy stuff like vacuum lines, intake elbow fit. If plugs and plug wires are old, you might consider doing maintenance on them.
Old Jul 25, 2003 | 08:23 AM
yeah
yeah plugs,air,fuel,cleaned iac motor, has all been done...i dont have a scan tool...maybe its time to invest but i was just wondering if they could be bad without throwing a code....ive been getting a damn p1441 so i replaced the check valve in the back of the vehicle and the hoses....also...the solonoid at the engine...and those hoses...so im stumped
Old Jul 25, 2003 | 08:40 AM
97 SLP Company Car's Avatar
Did you reset your ecm after the sol and and other evap lines? Also what is your vac at idle? Are you still getting that evap code?
Old Jul 25, 2003 | 09:03 AM
yeah
yeah i unhooked the batt. and had someone clear the code out...i was thinking maybe the switch....i know that when i did replace the check valve and the sol. it did help out a little bit...but i think maybe just a little more power is lacking...so im trying to figure this out...
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
