would i get a code?
If they are bad enough, yes.
Monitoring it with a scan tool should tell you if they are operating ok. Check easy stuff like vacuum lines, intake elbow fit. If plugs and plug wires are old, you might consider doing maintenance on them.
yeah
yeah plugs,air,fuel,cleaned iac motor, has all been done...i dont have a scan tool...maybe its time to invest
but i was just wondering if they could be bad without throwing a code....ive been getting a damn p1441 so i replaced the check valve in the back of the vehicle and the hoses....also...the solonoid at the engine...and those hoses...so im stumped
yeah
yeah i unhooked the batt. and had someone clear the code out...i was thinking maybe the switch....i know that when i did replace the check valve and the sol. it did help out a little bit...but i think maybe just a little more power is lacking...so im trying to figure this out...
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
BigDarknFast
3rd Gen / L98 Engine Tech
Jul 8, 2002 01:37 AM
