Would this hurt my Porformance??
Old Jun 26, 2005 | 12:10 AM
  #16
Z-RATED94's Avatar
Re: Would this hurt my Porformance??
I get mine from Jason Cromer. 1 850 243-8826. Give him a call. Good prices.
Old Jun 26, 2005 | 01:50 AM
  #17
white/blackss's Avatar
doesn`t the computer go into limp home mode when the o2`s crap out?
well if it does then yes it does hurt performance, when my car was in limp it ran like sh**.
got that service engine light off and bam all the power was therre again
Old Jun 26, 2005 | 11:41 AM
  #18
DiabloGT's Avatar
wait will pacesetter lts and y pipe, have holes for o2 sensors? and should i get 2 since i have one cat? and if i dont use a cat do i only need one or none?
thanks
Old Jun 26, 2005 | 11:42 PM
  #19
97BBlackZ's Avatar
thanks
The LTs should already have holes in them for the front o2s and as far as the backs you can either get sims or just get them deleted by a computer tune or www.madz28.com So really you only need 2 unless you plan on using your stock ones but those are a B!TCH to get out. And if you do get them out your lucky you dont strip them.
Old Jul 5, 2005 | 05:52 PM
  #20
DiabloGT's Avatar
so if i get the back ones deleted i only need one?
thanks
Old Jul 5, 2005 | 06:56 PM
  #21
matt65's Avatar
you dont think it would hurt though if i used a different brand do u?
I do. And another vote for the GM sensors.
Old Jul 6, 2005 | 03:29 AM
  #22
97BBlackZ's Avatar
thanks
well i know there is a difference between our cars. Mine being a 97, dual cats and your being a 95 1 Cat.. Also different computer, But it should be about the same.
You should have 2 O2's for the front before the cat. 1 for each side of the exhaust before they connect into the Y-pipe. Those are the ones that you will need O2 extensions for. 2 Total 1 for each sensor. The back ones you you can do 3 things with
1. Get O2 extensions for them to.
2. Get 02 Sims.
3. Get them programmed out.
My parts list when i did mine was pretty much.
Headers.
Header gaskets.
Header Bolts.
2 O2 extensions
Spark Plugs
Spark plug wires.
Things i left out when i did mine that i forgot or would change would prob have to be 2 new O2 sensors (wait till AFTER the headers smoke and the coating burns off ect before putting them in.) stripped one taking my stock ones out thankfully we fixed it. And the OTVC wire looms would have realllly helped. Also once you get them in make sure all wires are away from the headers.
Sorry was to tired to go back and check what the question was directed towards so i kinda just went over all of it lol.
Cam's maro
Aug 11, 2015 07:45 AM
colts0455
Jul 8, 2015 12:21 AM
jdelaprida
Jul 4, 2015 03:02 AM
jayblev95
Jun 7, 2015 04:04 PM
KarmaCult
3rd Gen / L98 Engine Tech
18
Oct 29, 2003 10:17 PM
