worn posi clutches???
Old Jul 9, 2003 | 12:40 PM
LWillmann's Avatar
How much can worn posi clutches affect the acceleration of a vehicle?
I know that worn clutches can affect the "one wheel peel" effect, but assuming good traction on both wheels, can they slow the general acceleration as well?
Old Jul 10, 2003 | 02:47 PM
LWillmann's Avatar
Anyone???
Old Jul 10, 2003 | 04:53 PM
xchief1320's Avatar
If the car isn't spinning then the posi isn't in effect,and both wheels are turning at the same speed,so that means no it doesn't hurt acceleration when the posi is going out only traction..
Steve
Old Jul 10, 2003 | 05:05 PM
anaik's Avatar
You have an Auburn posi. They don't have clutches. Here's their site, maybe it'll give you an answer.
http://www.auburngear.com/
Old Jul 10, 2003 | 05:07 PM
xchief1320's Avatar
Auburns use a cone style,it uses 2 cones on each side that push into each other to cause the posi..
Steve
Old Jul 10, 2003 | 05:38 PM
scoobysnax83's Avatar
How do you know
Old Jul 10, 2003 | 05:47 PM
anaik's Avatar
Originally posted by scoobysnax83
How do you know
That's what came from the factory till '98, then the Zexel Torsen.
Old Jul 10, 2003 | 06:00 PM
really..news to me... Is that all camaros, Auto and M6?
Old Jul 10, 2003 | 06:12 PM
anaik's Avatar
Correct, all LT1 F-bodys.
Old Jul 10, 2003 | 06:37 PM
Wow, I feels so stupid! Thanks
Old Jul 10, 2003 | 09:45 PM
LWillmann's Avatar
If I have no clutches in the posi, then why do I get one wheel peel?
Old Jul 11, 2003 | 03:51 AM
anaik's Avatar
It could be that the cone clutches are worn out or damaged. They are not clutches in the typical sense, that is, a number of flat discs that engage causing power to go to both wheels, like in an Eaton differential. In an Auburn, when the cones are shot, you have to get a new unit, as they are not rebuildable.
http://www.auburngear.com/aftermarke...differentials/
Old Jul 22, 2003 | 10:11 AM
CANTONRACER's Avatar
The cone style diffs suck major sack. I went thru a few before I finally got a diff out of a newer f-bod.
It has proven strong enough for many 11 second and 1.6 60 blasts and is rebuilable. I bought it from SLP as a take off for $100.
Good luck.
Old Jul 22, 2003 | 10:55 AM
LWillmann's Avatar
Unfortunately, every time I have called SLP for a take-off Zexel-Torsen for the last two months, they've been backordered with no ETA..
I've got my 3.42s and a different posi going in as we speak, so if that posi wears out, I'll be buying an Eaton most likely, or I'll say screw it and buy a 12-bolt.
Old Jul 22, 2003 | 01:10 PM
There was a guy selling a zexel take-off that he bought from SLP for $100 recently. Do a search, he might not have sold it yet.
Depending on how much power you plan on making down the road, you might not need a 12 bolt.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
