witch size stud for rocker arms
Old Feb 2, 2004 | 07:57 PM
jeepz28's Avatar
I'm geting ready to order some rocker arms but have a view questions. What size is the stud on stock heads for a 95 z28 is it 3/8 or 7/16. and what is the differencs between non-self-aligning and self-aliging rocker arms and witch one would be better.
Old Feb 2, 2004 | 08:14 PM
BadAssed93Z's Avatar
stock size is a 3/8 people with decent hp numbers usually up grade to 7/16.
i went with non self aligning, becase the guideplates are more security to me than the self aligning ones offer
Old Feb 2, 2004 | 08:16 PM
Aaronh's Avatar
The stock is 3/8 dont make the same mistake i did though, buy the bigger 7/16 studs and the appropriate rr's also if you plan to but in a bigger cam later get the non sa's and guide plates. If you have a 95 you already have hardend push rods so that will save you some jack.
Aaron
FacelessZ's Avatar
SA - <valve float
NSA - >valve float
Old Feb 2, 2004 | 08:17 PM
FacelessZ's Avatar
Aaron
Not all '95's have hardened pushrods...
Old Feb 2, 2004 | 08:19 PM
Stock rocker arm studs are 3/8".
SA rockers have small guides built in on either side of the roller tip to keep it centered on the valve stem.
NSA rockers have nothing to keep them centered and rely on pushrod guide plates for control.
There has been some recent threads on opinions of each, so you might try a search. IMO, the NSA setup is the more stable.
Old Feb 2, 2004 | 08:23 PM
Wild1's Avatar
Guide plates are encouraged as you step up the rocker ratio too.
Old Feb 3, 2004 | 04:36 PM
jeepz28's Avatar
thinks for the info
Old Mar 21, 2005 | 04:18 PM
Bersaglieri's Avatar
Re: witch size stud for rocker arms
Originally Posted by FacelessZ
SA - <valve float
NSA - >valve float
Can someone explain this? I havent heard of the SA vs NSA causing valve float.
-Dustin-
69z-28
Jan 29, 2016 10:46 PM
Sauced
Apr 12, 2015 10:18 AM
1775.Z28
Jan 11, 2015 10:51 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
squinn
Aug 4, 2002 01:06 PM
