Wiring problem?
Old Aug 13, 2005 | 11:10 PM
cb94ta's Avatar
Wiring problem?
Casrs always had some wierd electical quirks the beep you get when your doors open only works when I have the brake in for one but now my radio display(stock crap radio) has started flashing off and on and mainly does it when I hit the brakes. any ideas?
Old Aug 14, 2005 | 05:52 AM
slopokrodrigez's Avatar
Re: Wiring problem?
This is a stab in the dark but there is an audio alarm module in what is called the convenience center. It has a black 12 pin connector going to it and it is right below the I/P fuse panel. It is common to everything you listed. Try disconnecting it and see what the radio does at that point. When you disconnect it, you won't have the chimes anymore but you only want to temporarily narrow down your choices.
Also pull out and then put back the courtesy fuse, the gages fuse, the tail lights fuse, the I/P dimmer fuse and the radio fuse. I've seen fuses develope poor contact over time and just pulling and reseating them can correct the problem.
Old Aug 14, 2005 | 06:46 AM
cb94ta's Avatar
Re: Wiring problem?
Thanks I'll give it a try today hopefully I can get all these little oddities sorted out
Magenta_Hearts
Mar 25, 2015 10:24 AM
Scottyboy
Feb 11, 2015 10:28 PM
GigaMp3z
Feb 20, 2003 02:57 PM
BOOGER
Jul 25, 2002 02:42 PM
