wiring: I need a key-on power source inside (manual fan switch)
Old Sep 28, 2008 | 08:27 PM
Zrout's Avatar
I followed the schematics on shoebox's website, I have it all set and wired up, but I can't find a key-on only 12V source to tap into
I will have the switch somewhere in the area of the center console...
obviously the lighter is always on , I tried the radio and from what I know pink and orange wires are usually possibilities but pink only has juice when radio is ON , and orange is always on (for memory I suppose).
what else to try?
thank you in advance, I'm sure this is an easy question for someone who has done this I'm about to tap off a always-on source and put another switch in-line to cut it off
Old Sep 28, 2008 | 09:50 PM
What car is this on?
You can always run wire to the fuse panel. There are normally unused extra lugs for switched power.
Old Sep 29, 2008 | 08:54 AM
Zrout's Avatar
oh sorry, 95 Formula.
Old Sep 29, 2008 | 09:34 AM
BIG SHAFE's Avatar
Why do you need a key on only source?
If you tap into the radio harness, yellow wire is always hot and the red wire is usually a key on hot source. All you need is a volt meter.
Also, if you have an after market radio, you can use the blue wire from the radio harness for a key on source. The blue wire is for a power antenna. I think Camaro's didn't have power antenna's but some Firebirds did?
I think the orange wire is only illumination, i.e. when you have the headlights on and adjust interior lighting (dim light wheel/control).
If you have an M6, the reverse lock out I think is only on when the key is on, not sure of the voltage though.
cristian1311
Nov 23, 2014 02:22 PM
Jul 4, 2005 05:00 PM
slothgrant
Aug 22, 2002 03:01 PM
x7x7
Aug 15, 2002 06:49 PM
sfGi8nt
Aug 1, 2002 05:54 AM
