wire arcing to header
Old Jul 29, 2003 | 01:30 AM
lt4 fd's Avatar
Exactly how bad is this, the car seems to run perfectly, just one wire arcing to the header through some foil not bad though, how is it fixed and how bad is it?
Old Jul 29, 2003 | 01:36 AM
Rich_z28's Avatar
It's not a terrible thing, but it should definately be fixed. You're cars performance is suffering and might lead to some problems later on down the road. You can fix the problem by just replacing the wire.
Old Jul 29, 2003 | 07:24 AM
IDOXLR8's Avatar
I had the same issue when I was running Taylor wires on my car. My car was arching so bad that it began to backfire at idle. I would suggest replacing the bad wire and maybe stick a heat sleeve over the wire. Not replacing the wire can result in your car missing.
Old Jul 29, 2003 | 12:08 PM
lt4 fd's Avatar
what probs can it cause later down the road? and how far down the road? Ive had it on a day and it might stay on as long as a week...
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
CobraEatr
Jul 23, 2002 06:32 PM
