TDC & Different Head Gasket
Old Jul 25, 2003 | 04:29 PM
DjArcadian's Avatar
I am pulling my heads soon and I bought one Felpro gasket. If I was only the passenger side head can I determine TDC by piston position on that side? Also, since one gasket is stock and the other will be a Felpro gasket with the slight different in engine compression effect the engine at all?
Old Jul 25, 2003 | 04:34 PM
When #6 is all the way at the top, look at the lifters/cam lobes. Compare them to #1 and you should be able to tell if it is #6 or #1. You really don't need to worry about TDC unless you are pulling the opti or timing chain.
Old Jul 25, 2003 | 04:48 PM
DjArcadian's Avatar
I had problems with a misaligned harmonic balancer that a shop fixed. Since I was pulling the head I just wanted to make sure it was done correctly because I think it's off a few degrees.
So when piston #6 is all the way up it's at TDC? Does that mean piston 6 and 1 are at TDC at the same time?
Old Jul 25, 2003 | 06:17 PM
Yes, 6 and 1 are up at the same time. If all you are concerned about is the balancer orientation, you don't even care whether it is 1 or 6. The arrow on the balancer should be at 12 o'clock in either case.
Old Jul 25, 2003 | 09:32 PM
Transamdriver's Avatar
As shoebox said #1 and #6 are up at the same time. The cam determines which cyl. is at tdc, When the crank dot is at 12 o'clock and the cam dot is at 6 o'clock that is #6 TDC. You turn the crank 360* clockwise and the crank dot is back at 12 o'clock but the cam dot is at 12 o'clock also that is #1 TDC.
I just felt like typing that, dunno why.
Old Jul 27, 2003 | 11:55 AM
DjArcadian's Avatar
Are you saying that TDC is not actually determined by the position of the piston but the position of the CAM? So if I have the heads off my car and see the piston at the top that doesn't mean that it's actually at TDC?
Old Jul 27, 2003 | 11:59 AM
AsianSensation's Avatar
TDC means the pistion is on top it's compression stroke. Both valves closed. When #1 piston is at it's upmost travel, so will #6. TDC is determined by the cam. Lke shoebox said, look at the lifters/cam lobes.
Old Jul 27, 2003 | 12:05 PM
Its a "damper", not a balancer. Position on the crank isn't critical. If it was, they would have put a keyway in the damper hub to match the one in the crank, and installed a key.
Old Jul 27, 2003 | 06:34 PM
DjArcadian's Avatar
I'm surprised how many people believe this. Sorry Injuneer but you're not correct. The harmonic balancer is equipped with holes that have weights on it. Some LT1 engines don't have these weights and some do. My does and as a result I had quite a lot of vibrations when I installed wrong. The shop was able to align it correctly a lot of my vibrations went away. I'm still dealing with other vibrations.
It is a bonehead design flaw with GM not equipping the crank with a keyway though.
Old Jul 28, 2003 | 01:39 PM
I'm familiar with the holes, but the tolerance is on the order of 90degrees:
HUB AND BALANCER
The balancer is a two-piece assembly with a pulley that bolts onto the hub. Separating the two made it easier to install the Optispark distributor on the assembly line and out in the field. The holes in the hub are offset, so the balancer only fits on it one way, but there’s no keyway in the hub to index the hub on the crank. This shouldn’t be a problem unless the damper was drilled at the factory to "trim" the final engine assembly.
If it was drilled a lot to compensate for an engine that was out of balance, you could end up with a shaker, depending on how everything stacked up with the remanufactured engine compared to the original engine. If you encounter a balance problem on a remanufactured LT1, try rotating the balancer assembly on the crank 90° at a time to see if it eliminates the problem.
Old Jul 29, 2003 | 01:32 PM
DjArcadian's Avatar
I think they're speaking in regards as to how the balancer/damper fits on the hub and not as to how the hub fits onto the crank.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
