Wing nuts on cut-outs suck!
Old Jan 26, 2004 | 10:15 PM
  #16
jasons93z's Avatar
my cut-out came with a tool to tighten it tighter. BTW, even when i hand tighten it, they dont fall off
  #17
Kain's Avatar
When I had my cutout on the I-pipe before it went over the axle, the wing nuts were fine.
When I went to dual cutouts, the wing nuts worked themselves off and I had to go to regular nuts.
Old Jan 27, 2004 | 02:26 AM
  #18
96 WS6's Avatar
You are telling me that you did not hear the difference until you almost lost the cap??? WTF.
Old Jan 27, 2004 | 02:51 AM
  #19
ROADRAGE's Avatar
Me and a friend both have the same issue. We have both switched to regular nuts now. DO you have any mods? We both have cc306 cams and ported heads, so there is a lot more vibration than stock. could be why they wont stay tight.
And no, i didnt hear a difference when it was almost off.
Old Jan 27, 2004 | 08:44 AM
  #20
JIMS1999CONVZ28's Avatar
I have the same problem and keep an extra set in the console.
I do have and idea about keeping them on.
Just drill a small hole in each wing and wire them together, so you will have one single wire going through each wing on one side.
That way you can just snug them down, wire them up and then remove them easly for the strip.
Jim
Old Jan 27, 2004 | 11:32 AM
  #21
DB75's Avatar
I didn't even bother with the wingnuts because I heard of this problem before. I just use regular bolts and keep a ratchet in my car.
Old Jan 27, 2004 | 12:31 PM
  #22
Black_Z28's Avatar
I had wing nuts on mine. But since I changed the gasket, I thought I would change over to normal nuts. I just keep a 3/8" wrench in my car, so I can remove them whenever I want.
Old Jan 27, 2004 | 12:48 PM
  #23
Jag's Avatar
Jag
What's up AggieZ28! I live in Bryan. How much for your '95?
Old Jan 27, 2004 | 03:05 PM
  #24
chesee48's Avatar
mine always come loose after a while.
Old Jan 27, 2004 | 08:25 PM
  #25
WS6Formula's Avatar
Throw a split washer on there & they shoudl stay without a problem.
It's the kind of washer where it's cut & twisted a little so the ends don't line up. It helps keep pressure on the nut so it wont back off
Old Jan 27, 2004 | 09:08 PM
  #26
Cmr0z28's Avatar
The guy who welded mine in told me to put regular nuts on and torque them down because the wingnuts will vibrate off and I'll be driving and all of a sudden say "why is my car so loud all of a sudden?"
Old Jan 27, 2004 | 09:13 PM
  #27
leadfoot94's Avatar
You need to get an Electric Cut-out then you could "wrenchdown" the regular style hex nuts and not have to worry about them.
Jeff1904
Jun 5, 2016 05:00 PM
Kawi
Sep 28, 2015 09:01 AM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
Dams76
Aug 20, 2015 08:28 AM
