Window Regulator or Motor???
Old Sep 23, 2003 | 06:04 PM
drewstealth's Avatar
My drivers side window is almost gone. It only will go down or up for a sec. then i have to wait a few minutes for it to charge up again so i can move it again. Do i have to replace my regulator or the window motor. Also does anybody have the part #'s for the part that i have to replace. Thanks.
Old Sep 23, 2003 | 07:08 PM
There is some window motor info on my Tech Page in the "How To's".
Old Sep 23, 2003 | 07:43 PM
thx i'll check it out
Old Sep 24, 2003 | 02:11 AM
whitelightening's Avatar
window
I just had to have the motor reaplaced in my drivers side also and your problems sound similar to what i had. The part # on my bill says: part--42-150 window motor i don't know if this will help you at all. Good luck in trying to fix it i hope i was helpful to you.
Old Sep 24, 2003 | 09:42 AM
RedPhenx's Avatar
the motor is 53 or so at autozone.. lifetime warranty.. and then you get 20 back on a core charge
Old Sep 24, 2003 | 09:50 AM
Bando's Avatar
Same was happening to me, I did the protection circuit bypass...do a search you should find it...worked like a charm, no problems, nice and fast and doesn't stall out. You take the motor apart and solder a tab together and it's done.
Old Sep 24, 2003 | 10:05 AM
Brettinator's Avatar
$50 bucks at Autozone it's made my Siemen's I think and they are faster than stock. There are some good "how-to's" posted by Shoebox or somebody on this site that make it real easy to follow. Took me 30 mins for my driver side to completely finish it.
Old Sep 24, 2003 | 08:14 PM
IRONCROSS97's Avatar
Lightbulb just happened to my car
just channged my window motor,,,,,mine would go down about 3inches then stop. wait for about 3 mins try again it would move less.....definitly your motor......
Old Sep 24, 2003 | 09:00 PM
S.J.S.'s Avatar
K we all know its your motor. I just changed mine. If it's your motor your gonna need the huge *** rivets form the stealership (unless you can find somewhere else, I just gave up looking) and a huge rivet gun.
Old Sep 24, 2003 | 09:09 PM
No huge rivets needed with the method on my web page. The huge rivets are for the regulator. My method does not remove it.
Old Sep 24, 2003 | 09:22 PM
S.J.S.'s Avatar
Sweet Shoe.... I changed the whole thing because when I looked in the rubber or plastic on the rollers was all worn out and I was getting some metal to metal contact. Plus I had a friend in the parts dept so I just went with the whole thing. Wasn't that hard at all.
Oh but dude!!!! make sure you use gloves when your reaching in on that window motor area. I split myself wide open 3 times. It's sharper than a razor in there. I didn't even know I was bleeding. I'm talking go to the emergency room type slices.
Keenan
Jan 19, 2023 12:24 PM
kaoticcamaross
Feb 17, 2015 03:13 PM
capebuf
Jan 13, 2015 07:22 PM
