window problem...
Old Jun 10, 2003 | 08:32 PM
blak96SS's Avatar
window problem...
Ok, first of all my driver side window motor is on its way out, but after reading Shoebox's install, Im not too worried about that. HOWEVER, the reason for the motor failing is what has me worried. About a week or so ago, I was rolling my window up and once I got about 4/5ths of the way up, the window itself fell inward. I pushed it back out and rolled it up and didnt think much about it because I was in a hurry. The next day I noticed that I can move the window back and forth about 3 inches or so, and it still falls in when I try to roll it up. The strain has now caused my motor to start to fail. I tried searching, but couldnt find anyone else who has had the same problem. Whats wrong, and is it something I can fix myself? TIA.
Old Jun 10, 2003 | 09:24 PM
Cmr0z28's Avatar
mine kinda had the same problem. when you have the door panel off look in there when you're changing the motor. i put something under the window to support it
Old Jun 10, 2003 | 10:47 PM
blak96SS's Avatar
thanks, i'll take a look at it when i have the panel off. Anybody know exactly what is broken??
Old Jun 10, 2003 | 11:00 PM
Fatdog's Avatar
Cool
Yep.Part #16625875.About $50.00 0r so.(Maybe something just came loose,but if that little silver thing that makes the window go up and down is wobbly,then replace the whole bottom rail with this part #.).Hope this helps.
Old Jun 10, 2003 | 11:34 PM
rdavis93's Avatar
i had something similar-the motor was loose. ez fix if that's it.
Old Jun 11, 2003 | 12:35 AM
blak96SS's Avatar
thanks guys. Hopefully when I get it apart I can see exactly what is wrong. Do you have a name for that part #? I ran it thru gmpartsdirect, but it didnt come up with anything. I just like to have as much info as possible if I have to go to the dealer because, like most, they are stupid. Thanks again, guys.
OutlawPerforman
Oct 30, 2017 05:40 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
z28cam1993
Sep 9, 2015 04:08 AM
Jul 10, 2015 02:23 PM
