window crank removal
Old Nov 19, 2003 | 09:57 AM
bad1LEz's Avatar
Search = no answers
Have a 1LE (man. windows) and need to replace my window guide. How hard is it to take off the window crank without bitching up the panel and crank. Would Autozone carry a tool for this and are they universal for every make of car? Also, the door panels pop off with a little pressure right? Just held in with those plastic pop pegs? Do you automatically need new pegs when you pop them out, or just if they get messed up? Going to read along in Chilton's when I do it, just mainly worried about the crank tool. Can I ask 14 more questions???
Thanks as always
Old Nov 19, 2003 | 11:53 AM
ATMINF's Avatar
IF you gently push on the plastic interor door cover and look between the hand crank you can see there is a metal clip that helps to hold in the crank. Just pull the clip out and you will be able to slid the hand crank assembly out.
Old Nov 19, 2003 | 12:27 PM
Get a tool like this to get your crank off. There is also info in my window motor write-up that shows how to remove the door panel. Look on my Tech Page.
Old Nov 19, 2003 | 12:30 PM
Bad AZz Z28's Avatar
yeah i got them off my 1LE in a few minutes, but if there is a tool to help u, by all means get it, tools r good
Old Nov 20, 2003 | 07:01 AM
bad1LEz's Avatar
Thanks alot guys. Shoebox - AWESOME site
I can't walk and look up at the same time, wish me luck!
DirtyDaveW
Dec 1, 2016 05:37 PM
Heathen1
Jan 2, 2016 04:27 PM
warmeck
Feb 2, 2015 12:44 AM
warmeck
Jan 20, 2015 10:29 PM
