Wilwood Upgrade and Firehawk Wheels
Old Jul 10, 2003 | 04:01 PM
TheHeadFL's Avatar
Well, on Monday my Wilwood kit should arrive, and I'm trying to prepare where possible.
I am almost 100%, but not quite yet sure that the Firehawk rims have the same type of clearance that a WS6 or SS or stock wheel had. Has anyone had experience with this wheel and aftermarket brake kits? I am only worried about the caliper to spoke clearance, not caliper to rim, since I am 110% that it will fit diameter wise.
Also, I need to safety wire the rotor to the hat. Where can I pick up some safety wire? At the reccomendation of a friend of mine, I am skipping the safety wire pliers, and am just going to try to do it with some pliers wrapped in a soft tape, to prevent knicks and scratches. (Yes I know it will take much longer)
Also, I will be replacing the brake lines with stainless braided lines as part of this kit, so does anyone have tips for removing the brake line from the body side hard line? What size line wrench will I need?
My friend has a plasma cutter he will let me use to modify the knuckles, but I would have to do the install at his place in Orlando, and since I am current in West Palm, I'd rather try to do it with a sawz-all, but does anyone think I'd be far better off with the plasma cutter?
I have to do a 4 wheel bleed, I assume, and I plan to try to flush the entire system out with new fluid. What brake fluid does everyone reccomend? I am told to use either DOT3 or DOT4, but NOT DOT5.
What other specialty tools might I need?
Old Jul 11, 2003 | 03:46 PM
TheHeadFL's Avatar
ttt
Old Jul 19, 2003 | 02:25 AM
TheHeadFL's Avatar
ttt
Old Oct 29, 2003 | 06:19 PM
Acct 23749's Avatar
Hey if you find anything out please pass it on. I should be getting my wilwoods in about 2 weeks and am currious on all that information. Also if you could take pics i would love to see them.
In daytona here
EDIT
I just looked in your sig.... DAHHMMM cant wait till i get mine
nice page
TitoPR221
Parts Wanted
Jan 10, 2015 09:21 AM
GigaMp3z
Feb 20, 2003 02:57 PM
3FifteenPlus
Jul 30, 2002 12:47 AM
