Will my LT1 rear brakes fit on my new 2000 rearend?
Guys, got a big problem here. I'm leaving in a few to bolt up my new rear - a 2000 3.42 rear. Problem is I don't have the rear rotors from the 2000. Can I use my stock 94 rotors on this rear? What do I need to change over brake wise? Thanks
Originally posted by EviLZ28
You can do that. You just need to switch everything from your old to the new.
Seems like it would just be easier to get a pair of new rotors.
Originally posted by shoebox
You will also have to swap the old axles from your existing rear end. The axles are slightly different lengths.
I have the rear Auburn unit from a 98 WS6 and they only used the gears and housing.. Axles, Brakes, etc were all swapped.
bossco
Nov 29, 2014 10:18 AM
