will this intake work with my 94 fuel rail etc
Old Aug 16, 2005 | 04:55 PM
94irocz's Avatar
93 intake on a 94-97 motor what do i need??
I bought a ported intake and it turns out its for a 93 camaro since it doesn't have the notch in the front of the intake for the cross over tube on the fuel rail. What do I need to make this work with my 94 fuel rail and injectors????
Do I need to get a 93 fuel rail, if so what do I need to do to swap over my 94 injectors and regulator etc?
Basically what I am asking is what do I need to do to make a 93 intake work on a 94 lt1. will my holly 58mm tb work on this intake?
thanks
Old Aug 17, 2005 | 06:19 AM
94irocz's Avatar
Re: 93 intake on a 94-97 motor what do i need??
Ttt
Old Aug 17, 2005 | 10:15 AM
I can't see how you could put any rails other than the 93 rails on a 93 intake manifold. Only other possibility would be to remove the diagonal cross-over pipe from your 94 rails, weld the holes closed, and drill new holes on the top of the rails so you could weld in some -6AN fitting and use a braided S/S hose looped over the intake.
I've always wondered how the 93 rails will work with the sequential injection used on the 94+'s, since the 93 rails were designed to work in batch-fire mode. Probably no significant difference.
The 58mm TB should fit, as long as the holes have been open up from the stock 52mm.
Old Aug 17, 2005 | 12:11 PM
94irocz's Avatar
Do you think it would be possible to cut the cross over notch into the 93 intake so I could still use my 94 fuel rail? From 93 to 94 are the regulators the same what about the map sensor etc.
Thanks joe
HectorM52
Jul 30, 2017 11:46 AM
LT14LIFE
Feb 9, 2015 09:35 PM
birdblack
Dec 30, 2014 06:59 PM
Catmaigne
Dec 25, 2014 12:16 PM
Jul 4, 2005 05:00 PM
