Will The 26x11.5x16 Et Streets Fit In Fender???
Old Jun 17, 2003 | 01:36 PM
InjectedSS's Avatar
im wondering if i can go with the 26x11.5x16 with some stock 5 star wheels! or if i should just get the 26x10.5x16's? were talking et streets here will the 11.5's fit in the fender well or do they rubb?
Old Jun 17, 2003 | 01:52 PM
Derrick Redd's Avatar
I ran the 26x11.5x16 ET Street without any modification to the wheelwell. You should be fine.
Old Jun 17, 2003 | 03:13 PM
InjectedSS's Avatar
no rubbing on the inside of the fenders then eh!
Old Jun 17, 2003 | 03:17 PM
A 26x11.5-16 ET Street has a section width of 10.8". That's less than the 275/40-17's that come stock on a WS6 or SS. It will fit fine. M/T does recommend a 10" wide wheel for that size ET Street.
Old Jun 17, 2003 | 03:21 PM
InjectedSS's Avatar
really. i think the stock wheels are 16x8... so would these not work then i was running 26x10.5x16's on a set of salad shooters with no problems.. i wasnt running tubes either.. so should i just get another set of 26x10.5x16's or can i run the 26x11.5x16's on salad shooters with no tubes
Old Jun 17, 2003 | 03:25 PM
When I ran the 26x11.5x16's they were on 8" stock wheels without tubes. Worked fine with traps in the mid 120 range.
Old Jun 17, 2003 | 04:21 PM
InjectedSS's Avatar
werd... so you didnt have ne issues with them rotating on the rim or nething like that then
Old Jun 17, 2003 | 06:55 PM
Not that I know of. Best 60ft. was a spinning 1.61 on N20. NA they would dead hook. 1.68-1.70
Old Jun 17, 2003 | 06:59 PM
rskrause's Avatar
Moderator
I ran 'em on a 16x8" rim with no problems. 1.51 sec 60' with a stiff street type suspension.
Rich Krause
Old Jun 17, 2003 | 08:00 PM
RichJ's Avatar
I had no problems with them on stock wheels. Keep in mind that the 26x10.5s are shorter than the 26x11.5s, so you'll see some gearing difference between the two.
Old Jun 18, 2003 | 10:12 AM
HungryT/A's Avatar
Derrick,
As far as I remember you were running the discontinued ET Drags. Were you pulling your 1.61 short times with them?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
roofo
Aug 26, 2002 02:00 AM
