will 16x9.5 et streets fit under fenders?
I was thinking of getting a set of et streets or dragslicks.I wanted to put them on my stock rims.Will the 16x9.5 fit inside the fenders?My car has the sportline springs that is why I ask.The tires have to fit inside the fenders.I don't want to rub at all.Thanks Jeff
94 white Z28,looks good,runs good,sounds good!
I've run them and know a few people that have run both sizes(11.5s and 10.5s) of ET Streets on a 16" rims and have had no problems.
Jason
Plates: "Stock 95"
1995 Firebird Formula
O'ring/4bolt 383, GTP Race Ported AFR 210s, Yank TH400, Yank 3800 Stall, Trans Break, Moser 12 Bolt w/ 3.73s, and the usual stuff like Hooker Long Tubes, Holley 58mm TB, Sphon Torque Arm, etc....
Jason
Plates: "Stock 95"
I run 26x11.5x16 ET Streets on 16x9.5 Centerlines, no rubbing whatsoever.
94 Firebird Formula Ram-Air, M6, T-tops, N2O, 12-Bolt, Bolt-Ons; was running 11's internally stock.432.8 RWHP / 588.4 RWTQ
No new times or dyno numbers with new top end (CC306, 1.6RR's, ported heads, etc.)
Not sure about the Sportlines. But with Eibach Pros 16x11.5 ET Street fit on salad shooters. The Sportlines drop the car even further, right? I did remove a portion of the inner fender lip at the bottom rear corner. There wasn't much clearance and I was worried about tire expansion causing interference.
Rich Krause
'95 Z-28 383 with Vortech, nitrous, etc.
"1FASTZ28"
Rich Krause
"1FASTZ28"
F'n1996Z28SS
Aug 23, 2023 11:19 PM
