Wild cam need HELP
Old Jan 13, 2005 | 04:15 PM
Schurters LT1's Avatar
Wild cam need HELP
Cam 224/236 116LSA XE 3192 3196 lobes this is the cam i will be putting in my FI 355..
Right now i am looking at a set of AFR210 raceready 70%cnc
What spring will work on these heads I will have a 1.6rr on the int/ex..I have been told this cam will peak in the 6200rpm range, I would like to have spring to live at 6500rpm
http://www.compcams.com/Technical/C...TML/340-349.asp
I looked at the Comp beehives 26918..but these spring are only good to .600..my cam is at .624 on the ex with a 1.6rr..
My Valve train right now is
comp R lifters
1peace CM push rods
guid plates
1.6rr pro mag
what do people think of these springs
#K-800 - 1.460 DIAMETER DOUBLE SILICONE SPRING GOOD FOR CAMSHAFTS WITH UP TO .700 LIFT. 155#@1.850 - 450#@1.150 - COIL BIND @1.085
Can the comp R lifter work with that much closed, as they will lose some with heat
Old Jan 13, 2005 | 04:58 PM
rskrause's Avatar
Moderator
Re: Wild cam need HELP
You can use the beehives. Coil bind is 1.085". If you install them at 1.825" you will have >120lbsi on the seat and still have enough coil clearance.
Rich
Old Jan 13, 2005 | 05:01 PM
Rich, is 120 on the set ok i was thinking of 130+....how do you no what you need on the seat
rideordie
Nov 5, 2019 04:52 PM
MattFick
Feb 15, 2015 10:16 PM
chuyz28
Nov 25, 2014 11:14 PM
Queens94z28
Nov 20, 2014 06:03 PM
