wideband placement question
Old Apr 9, 2011 | 01:20 PM
camarolt4ss's Avatar
So im running a ptk turbo kit on my lt4, and she is smoking (fuel) bad... i just changed the pre "cat" sensor, still smoking bad,
now i have a o2 sensor in the dp area of the turbo, but i honestly have ZERO idea which sensor this is, as there is no markings on her....
now id like to ideally run a wideband to help tune her up and keep it running nice and clean....
any suggestions on if that is a good placement for the wideband to go, or if anyone knows the part # for the o2 used in the ptk kit..
Cheers
Old Apr 9, 2011 | 02:46 PM
Re: wideband placement question
Since the PCM controls the engine as two independant banks, the best thing to do is to add a bung to both sides of the Y-pipe, to allow you to monitor either bank.
For questions specific to the turbo kit, you would need to post on the "Forced Induction" forum.
Which pre-cat sensor did you change - you have two of them, one for each bank.
Old Apr 9, 2011 | 03:43 PM
actually i only have 2 o2 sensors in the full system lol...... the one with the harness at the back of the block, which i believe is ment to be the manifold one, is up at my turbo dp....
the other one is in my exhaust which would be pre cat....
so i just swapped them both out, and the car is still running rich
Old Apr 9, 2011 | 08:03 PM
There is no O2 sensor on the block. They are all in the exhaust system. The only sensor on the back of the block is the oil pressure sensor.
Old Apr 9, 2011 | 09:06 PM
Yes i know that, i never said it was on the block, i was giving reference to where the plug was.....
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jun 6, 2015 08:27 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
