why is oil being pushed out my valve cover breather?
Old Jan 4, 2008 | 11:33 AM
4SFEDZ's Avatar
the car is a 94 lt1 385 with a t76mm turbo, just kind of putted it down the road and came back, cause its not tuned, and there was some oil coming out the breather, why? should i have one in each valve cover? i only have one in the pass side.
Old Jan 4, 2008 | 11:55 AM
BUBBA's Avatar
Make sure your PCV valve is not boogered. Don't know where it is on your engine, but usually located in middle of intake on Driver's side (LH).
If for some reason on another the pressure in the crank case is more than PCV can handle, all sorts of stuff can happen. JMHO
Old Jan 4, 2008 | 11:56 AM
dangalla's Avatar
are the rings seated properly?
Old Jan 4, 2008 | 12:32 PM
Did you modify your PCV system to prevent the turbo from pressurizing the crankcase?
Old Jan 4, 2008 | 02:37 PM
4SFEDZ's Avatar
not sure what your talking bout but dont think so, i still have the pvc valve and the little u in the drivers side of the intake, and its all new.
Old Jan 4, 2008 | 02:48 PM
4SFEDZ's Avatar
well i replaced the pvc so its brand new
Old Jan 4, 2008 | 02:49 PM
4SFEDZ's Avatar
i think so? how am i suppose to know for sure?
Old Jan 4, 2008 | 05:01 PM
The stock PCV valve uses intake manifold vacuum to evacute the crankcase. It lets fresh air in through the line attached to the passenger side valve cover, from the throttle body. If you kept all that intact, when you are under boost, the crankcase will be under full boost. Did you keep the stock PCV valve in place? Did you remove the vent line from the TB to the valve cover?
I know in blower applications, it isn't unusual to route the PCV valve to the inlet side of the compressor, with a catch can to eliminate entrained oil. That way you won't be pressurizing your crankcase, and blowing stuff out the breather.
Old Jan 4, 2008 | 05:05 PM
FASTFATBOY's Avatar
Let your rings seat BEFORE you step on it, about 150 miles or so, you need a one way check valve put in the pcv line to stop the crankcase from being pressurized by boost.
David
Old Jan 4, 2008 | 05:40 PM
4SFEDZ's Avatar
ok ive been doin some research and i have a bullet muffler so i dont have much back pressure. could i use my exhaust as a vacuum and run this into both valve covers with a filter of some type to catch the oil, and maybe a one way valve just to be safe? would there be any disadvantages?
Old Jan 4, 2008 | 11:05 PM
4SFEDZ's Avatar
what bout this? http://app.infopia.com/Shop/Control/...d/0/rid/126348
Old Jan 5, 2008 | 11:06 AM
You really should go on the Forced Induction forum, and find out what people with setups similar to yours have done.
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
