Who Wants a MSD Replacement for the Opticrap?
Old Aug 29, 2002 | 08:35 PM
  #76
1BadBird's Avatar
Post
Count me in as well. That money would be well spent getting rid of Gm's big mistake.
95 White T/A. A4,1Le elbow,Accel 300+ ignition,SLP CAI,MAC headers,straight pipe,SLP Loudmouth,Tb Bypass,Air foil,160 Thermostat,Blue Taylor OVC Wires
Old Aug 29, 2002 | 08:42 PM
  #77
dreamer1q's Avatar
Post
I can GUARANTEE I would own one as soon as it was available!!!!!
Arrest ME Red 1994 Camaro Z28 Convertible
just a chip and a muffler, well maybe some headers
First run EVER
R/T - .675 (on a pro tree)
60 FT - 1.943
1/4 - 13.969 @ 98.77
http://home.attbi.com/~mycamaro/
Old Aug 29, 2002 | 08:51 PM
  #78
n2oCamaro's Avatar
Post
I would diffently buy one as long as the quality was good. I have only used MSD ignition parts since I've owned the car. I have been waiting for an aftermarket company to make a better Opti or a whole new design.
A message to MSD-Not only look at this post, but all the other posts in the LTI Tech section. Do a search of the word "Opti" and see how many times someone has posted about problems or replacment. There is more than enough LT1 owners out there to validate a product.
Darrell
95 Z28 (Blue w/ white stripes)
Mods-Exhaust, Gutted cat, AS&M C.C. Headers, All the bolt-ons, Full MSD ignition, Nitrous Works Kit, Walbro 255 in tank pump, 4.10's, Lt1 Edit
Best 1/8 e.t.(n/a) 8.70@81mph
Best 60 ft.(n/a) 1.97
Times are with 6-10* false knock.
No current nitrous times.
383 parts collection underway.
Old Aug 29, 2002 | 09:28 PM
  #79
Koby's Avatar
Post
I am in. With my new ignition I am sure the opti won't handle the power very long. I would love a new one that is waterproof.
Old Aug 29, 2002 | 09:30 PM
  #80
mbc9ie's Avatar
Post
count me in...
i think we all are waitin for the day that we can take a sledge hammer to the 'ol opti...
Silver, 95Z, A4, 3.23's, homemade CAI, TB bypass, MAF screen, boot converted to a 1LE style, borla catback, gutted cat, upgraded coil, HPP III, 160 thermo, 8.8 mm wires, numerous tires, and 9 spark plugs (guess dealership thought i didnt need that 8th one till later
Fast enough to beat an '01 gt
Old Aug 29, 2002 | 09:46 PM
  #81
Grease's Avatar
Smile
I'm definately in, I think mine is going bad right now.
Green 1995 Z28, 6-Speed
Best ET: 12.616 @ 110.33 mph, 1.869 60ft
Race weight: 3430lbs
Old Aug 29, 2002 | 09:52 PM
  #82
My84Z's Avatar
Post
i am in mine is dying right now how is this going? let me know if this is gonna go through!
95 Z28 M6 with slp coated headers,slp 2otl cat back, cross drilled rotors, deleted maf screens,airfoil,slp sub frames, slp 160 thermo., slp skip shift elim.,slp air temp. module, slp cold air intake, Lt4KM, comp cams gold 1.6 rr's,lt4 clutch and pressure, energy supspension tranny mount, flowtech cutout, Taylor 8 mm wires over the valve cover, bf goodrich dr's, new best 12.88 with a 1.97 60'
88 jetta winter beater
87 honda cbr 600 hurricane fun to blast around on
Old Aug 29, 2002 | 10:02 PM
  #83
Jasen's Avatar
Thumbs up
I'd buy one the first day they were available. I'd have more piece of mind having the reliable bright red MSD upgrade/replacement for the opti-splat!
'97 30th Aniversary, TNT Nitrous and more mods than Frankenstein
Old Aug 29, 2002 | 11:48 PM
  #84
Z-GUY's Avatar
Post
load it crawled under from my ranting and my rock i dug it up because im sick of my opti problems, 4 optis is enough, in combo with this thread:
http://www.ls1.com/forums/showthread...hreadid=153033
Electro motive makes a crank trigger assembly which is badass but you loos some of your dash functionality... ie gauges and its 2400$$$ so you gotta be rich to own it but its adjustable to 0.1 degree of timing and replaces your pcm all together. it can also handle nos setups and up to 30 lbs of boost and you can reprogram it on the fly.. which is kinda cool but only if you want a hard core dragster...
1997 z28, ported afr 195cc lt4 heads, port matched lt4 intake; 617/640 244/244 @114. bmr boxed subframes, slp 1 3/4 headers, 72mm maf, k&n cai, p275 40 17 nitto drag radials @ 15 lbs, 3600 PI. vig stall (7 pump) converter. 373:1 gm gears, 58 mm TB. needs some track times and a dyno run or two.. maybe after i install my flux capasitor and my blinker fluid.
Old Aug 29, 2002 | 11:54 PM
  #85
Pandamonkey's Avatar
Post
When my stock Opti packs it in - I would definetally buy an aftermarket MSD rather than GM crap.
Anouther vote for yes!
Old Aug 30, 2002 | 10:19 AM
  #86
1 Hot Z's Avatar
Post
I am in for one also. We need one that's better than the gm opti-crap.
Old Aug 30, 2002 | 10:33 AM
  #87
bullitt_68's Avatar
Post
count me as another yes...
Old Aug 30, 2002 | 10:39 AM
  #88
GREGG 97Z's Avatar
Post
My opti has worked fine so far (knock on wood) but if it does go I would definitely be interested in an alternative.
97Z/28 Silver, M6, T-Tops, B&M ripper, 4:10's, SLP headers, SLP CAI, SLP clutch, Borla catback, PCMforless & some other stuff
Best 1/4 13.227 @106.19 2.072 60' at Cecil County, MD (before gears & programming)
Old Aug 30, 2002 | 03:55 PM
  #89
akafred's Avatar
Post
how hard could it be all you need is a optical sensor that replaces the whole opti spark, 4 or 8 coils, and a pc board that switches the power to the approite coil. the pcm allready knows which cylender is firing or at least which injector to fire (sorry 93 guys) so it should be realy simple to do. a few transistors a coulple coils and a machined optical housing and your done. i would do it myself but i dont have the 2000$ it would take to engeneer it but msd should?
95 camaro z28 6 speed K&N cold air intake, tb bypass, 1le elbow, and gutted cat. more to come when more $$$ comes
Old Aug 30, 2002 | 04:08 PM
  #90
Eddie95Z28's Avatar
Post
It isn't quite THAT easy...
I would definiatly be in line for a resonably priced alternative.
Eddie R. "Much clown luv!"
I have some mods too!
Yahoo: CrackerBalls95
AIM: CrackerBalls95 ICQ: 1651571
